? A product the Removes Rust without harming paint. #1046153
08/02/11 10:38 PM
08/02/11 10:38 PM
Morgantown, WV
1970 Drop Top Offline OP
Morgantown, WV
I my 1970 Challenger has what appears to be rust spec along the lower panel. It looks like tar, but I think it might be small bits of surface rust. The car was store for over 20 years without a wash. Does anyone know of a product or process that can assist with removing the rust, without harming the paint. I would like to keep it as close to original as possible. Thanks
[image]http://http://s1106.photobucket.com/albums/h378/Tal7123/?action=view&current=100_0104.jpg[/image] Sorry, I can figure out what I am doing wrong to add photo.
Re: ? A product the Removes Rust without harming paint. [Re: 1970 Drop Top] #1046154
08/02/11 11:24 PM
08/02/11 11:24 PM
70duster340 Offline
70duster340  Offline
You could try a product called Evapo-Rust. Not sure if it will harm the paint, but it claims to be environmentally friendly. I used it on a rusty barrel on a muzzleloading rifle I have. It didn't harm the bluing, so maybe it won't harm the paint? You need to somehow submerge the rusted part, though. It removes the rust in minutes, or so it claims. It did well for me.
Re: ? A product the Removes Rust without harming paint. [Re: 70duster340] #1046155
08/03/11 12:10 AM
08/03/11 12:10 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Submerging your "part" is obviously out of the question !! Fill a spray bottle and spray the areas and keep them wet. It would help if you used a soft brush and lightly scrup the areas as well. If the rust is light like you say then it should clean up quickly.
So, once you've gotten rid of the rust, then what ?!?!?!
Re: ? A product the Removes Rust without harming paint. [Re: 1970 Drop Top] #1046156
08/03/11 10:29 AM
08/03/11 10:29 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
There should not be two http://
I took it off and still didn't work. It is probably too big. Here it is smaller.
Re: ? A product the Removes Rust without harming paint. [Re: GomangoCuda] #1046157
08/03/11 05:35 PM
08/03/11 05:35 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
did you try good old fashion rubbing compound?
Re: ? A product the Removes Rust without harming paint. [Re: mikemee1331] #1046158
08/03/11 06:42 PM
08/03/11 06:42 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
how about CLR? its in the cleaner section in your grocery store
I am truckless..
Re: ? A product the Removes Rust without harming paint. [Re: mikemee1331] #1046159
08/03/11 06:43 PM
08/03/11 06:43 PM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
I have had great luck with turtle wax's chrome polish... it has something in it that will eat rust down to the smallest speck, and won't harm paint, other than making it shiny.
It also works well on plastic lenses and other stuff, but I've cleaned pot metal trim and chrome plating that looked awful and had it cleaned down to the specs of corrosion that had went through to the metal... I use it on my rims where the rust collects in the groove of the outer lip...
The Blue Goose
My instagram: Bossride
Re: ? A product the Removes Rust without harming paint. [Re: BossRide] #1046160
08/03/11 10:37 PM
08/03/11 10:37 PM
IN
ahy Offline
ahy  Offline
IN
I'd go the rubbing compound or chrome polish route then follow with a coat of wax.
Re: ? A product the Removes Rust without harming paint. [Re: 1970 Drop Top] #1046161
08/04/11 10:56 AM
08/04/11 10:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What do you plan to do with the bare metal once the rust is removed ?
Re: ? A product the Removes Rust without harming paint. [Re: JohnRR] #1046162
08/04/11 11:12 AM
08/04/11 11:12 AM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I have good luck with the "safest rust remover" you can apply it right to the spot. Cant say for sure about the paint I have only submerged the parts when I used it.
Scott
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: ? A product the Removes Rust without harming paint. [Re: JohnRR] #1046163
08/04/11 07:03 PM
08/04/11 07:03 PM
Morgantown, WV
Morgantown, WV
Once the rust in removed. I hoping to do some touch up primer and paint work to the individual spots, unless someone has a better idea. Remember, I am not too worried about noticing to touch ups, because I am not planning on restoring the car. It will be left as a survior.
