? A product the Removes Rust without harming paint.
#1046153
08/02/11 10:38 PM
08/02/11 10:38 PM
Posts: 31 Morgantown, WV
1970 Drop Top
Morgantown, WV
I my 1970 Challenger has what appears to be rust spec along the lower panel. It looks like tar, but I think it might be small bits of surface rust. The car was store for over 20 years without a wash. Does anyone know of a product or process that can assist with removing the rust, without harming the paint. I would like to keep it as close to original as possible. Thanks
[image]http://http://s1106.photobucket.com/albums/h378/Tal7123/?action=view¤t=100_0104.jpg[/image] Sorry, I can figure out what I am doing wrong to add photo.
Re: ? A product the Removes Rust without harming paint.
[Re: mikemee1331]
#1046158
08/03/11 06:42 PM
08/03/11 06:42 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
how about CLR? its in the cleaner section in your grocery store
I am truckless..
[Re: mikemee1331]
#1046159
08/03/11 06:43 PM
08/03/11 06:43 PM
Posts: 1,978 Southaven, MS
BossRide
Southaven, MS
I have had great luck with turtle wax's chrome polish... it has something in it that will eat rust down to the smallest speck, and won't harm paint, other than making it shiny.
It also works well on plastic lenses and other stuff, but I've cleaned pot metal trim and chrome plating that looked awful and had it cleaned down to the specs of corrosion that had went through to the metal... I use it on my rims where the rust collects in the groove of the outer lip...
The Blue Goose
My instagram: Bossride
[Re: 1970 Drop Top]
#1046161
08/04/11 10:56 AM
08/04/11 10:56 AM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
What do you plan to do with the bare metal once the rust is removed ?
[Re: JohnRR]
#1046162
08/04/11 11:12 AM
08/04/11 11:12 AM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I have good luck with the "safest rust remover" you can apply it right to the spot. Cant say for sure about the paint I have only submerged the parts when I used it.
Scott
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
