Correct T/A Six Pack air clearner base finish #1045379
08/01/11 09:48 PM
08/01/11 09:48 PM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
Is the corret finish matte or semi-gloss black?
Whats the best rattle can that duplicates the correct finish?
thanks,
B5 Challenger T/A
Re: Correct T/A Six Pack air clearner base finish [Re: KARLN] #1045380
08/01/11 10:02 PM
08/01/11 10:02 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The factory finish is "gloss black",...the factory "cheesy" looking gloss black... which can be on par with some of the 'semi-gloss" blacks today
Re: Correct T/A Six Pack air clearner base finish [Re: DAYCLONA] #1045381
08/02/11 02:32 PM
08/02/11 02:32 PM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
have you had an luck duplicating the finish with a rattle can paint?
B5 Challenger T/A
Re: Correct T/A Six Pack air clearner base finish [Re: KARLN] #1045382
08/02/11 03:04 PM
08/02/11 03:04 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Rattle can finish is what they looked like, it wasn't fancy even though we like them to look fancy.
logan426
Re: Correct T/A Six Pack air clearner base finish [Re: MLR426] #1045383
08/03/11 08:21 AM
08/03/11 08:21 AM
N. Dak.
RareTA Offline
super street
RareTA  Offline
super street
N. Dak.
I used Krylon semi flat black. Don't know how correct it is but it sure looks nice to me.
'09 Challenger R/T '70 Challenger T/A 340 6Pak and Auto I was born with nothing and I still have most of it left!
Re: Correct T/A Six Pack air clearner base finish [Re: RareTA] #1045384
08/03/11 10:15 AM
08/03/11 10:15 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
You can use a rattle can gloss black. it will dull down ever so slightly once it goes thru a few heat cycles
Re: Correct T/A Six Pack air clearner base finish [Re: KARLN] #1045385
08/03/11 10:35 AM
08/03/11 10:35 AM
Texas
Texican Offline
Texican  Offline
Texas
Rattle Can Semi-Gloss works fine, but my suggestion is to go anywhere that sells (auto paint)...not Orielly or Autozone.. and buy a can of the following paint:
Trim Black made my SEM... it comes in a tall white and purple can.
Re: Correct T/A Six Pack air clearner base finish [Re: KARLN] #1045386
08/03/11 12:37 PM
08/03/11 12:37 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
I like to powder coat these items. They get handled around so much that a durable finish is almost a must if you want it to look good for a loong time. The coater I use has a finish that is like 65% gloss and is perfect for these types of parts.
MB
Re: Correct T/A Six Pack air clearner base finish [Re: Texican] #1045387
08/03/11 03:27 PM
08/03/11 03:27 PM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
I really like the SEM trim paint but didn't think there was enough gloss to match the correct finish.
B5 Challenger T/A
