Challeger Covert. windshield frame height dimension. #1043602
07/31/11 12:12 AM
07/31/11 12:12 AM
Central Pa.
Cloned_Cuda Offline OP
Central Pa.
Anyone have a drawing with height dimensions to check the windshield frame, it appears to be low on
the drvers side or to high on pass. side. Thanks!!!
Re: Challeger Covert. windshield frame height dimension. [Re: Cloned_Cuda] #1043603
07/31/11 02:06 PM
07/31/11 02:06 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
there probably will not be any specs for that dimension. i have never seen any myself.
look at how the windshield, door glass, and how the top fits to the header to determine height. with those parts installed it should be easy to figure it out.
perception is 90% of reality
Re: Challeger Covert. windshield frame height dimension. [Re: Cloned_Cuda] #1043604
07/31/11 02:22 PM
07/31/11 02:22 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
are you sure it's not an illusion ? mine appeared high on the driver side when working on it. I believe my deminsion from the rocker to the top corner pinch weld on the bottom of the frame was 53 1/2 I'll try to remember to go back in some e-mails and see if I can find out where I put that measurement. Several people on this board possibly have converts striped out and can measure
that demension if they take the time to do it.
logan426
Re: Challeger Covert. windshield frame height dimension. [Re: MLR426] #1043605
07/31/11 04:35 PM
07/31/11 04:35 PM
Central Pa.
Central Pa.
Thanks Logan,
I failed to mention that the windsheild frame was cut from old fire wall (was in very poor shape),
and attached to a more solid firewall.
Re: Challeger Covert. windshield frame height dimension. [Re: Cloned_Cuda] #1043606
08/01/11 10:22 AM
08/01/11 10:22 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
I could tell from your post you had replaced the frame. Still looking for my notes.
logan426
Re: Challeger Covert. windshield frame height dimension. [Re: MLR426] #1043607
08/03/11 09:39 AM
08/03/11 09:39 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Sorry I'm unable to find the measurements. Ok members get a measurement and reply.
logan426
Re: Challeger Covert. windshield frame height dimension. [Re: MLR426] #1043608
08/03/11 01:50 PM
08/03/11 01:50 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Is convertible windshield the same as hardtop? If so, shouldn't the measurements be the same? If yes to both, I could grab some measurements off a project I am working on. Its a hardtop, well, sort of, until I get the roof skin back on.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Challeger Covert. windshield frame height dimension. [Re: RoadRunner] #1043609
08/03/11 03:11 PM
08/03/11 03:11 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Problem is measuring from the same frame reference point at the frame corner pinch weld to the top of the rockers. Convert would be best. May try from the center of the front floor pan foot well to to the windshield pinch weld to get another measurement point.
logan426
