68 Charger clear hood blinker indicator - stock? #1038556
07/23/11 04:33 PM
07/23/11 04:33 PM
Spring, TX
70cudaproject Offline OP
Spring, TX
I went over to my buddy's shop who has a '68 and '69 Charger he is restoring, and both had yellow/orange hood blinker indicator lights with small indentions in the middle. My '68 Charger has clear lenses that do not have any indentions. Are mine stock?
Re: 68 Charger clear hood blinker indicator - stock? [Re: 70cudaproject] #1038557
07/23/11 04:38 PM
07/23/11 04:38 PM
Spring, TX
Spring, TX
Picture under hood:
Re: 68 Charger clear hood blinker indicator - stock? [Re: 70cudaproject] #1038558
07/23/11 05:32 PM
07/23/11 05:32 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
68-69 charger hood turn signal lens assembly:
Re: 68 Charger clear hood blinker indicator - stock? [Re: 70cudaproject] #1038559
07/23/11 08:20 PM
07/23/11 08:20 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
NOPE!!! Sorry
Re: 68 Charger clear hood blinker indicator - stock? [Re: 70cudaproject] #1038560
07/23/11 09:17 PM
07/23/11 09:17 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
And the cars that didnt have the hood blinker did not have the holes punched in the hood.
Re: 68 Charger clear hood blinker indicator - stock? [Re: sthemi] #1038561
07/23/11 10:08 PM
07/23/11 10:08 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
I don't know about that. Back in 1990 I had bought a rusty and wrecked 69 Charger 383 4 speed for $350. It had delete plates where the hood turn signals mount. I think I still have them around here somewhere. But to find them now would be trouble.
Re: 68 Charger clear hood blinker indicator - stock? [Re: 70cudaproject] #1038562
07/23/11 10:14 PM
07/23/11 10:14 PM
New Jersey
MoparMedley Offline
MoparMedley  Offline
New Jersey
Both my '68 and '69 had ambers. From the look of the underside of that hood it looks modified.
Re: 68 Charger clear hood blinker indicator - stock? [Re: MoparMedley] #1038563
07/24/11 04:30 AM
07/24/11 04:30 AM
Spring, TX
Spring, TX
Thanks guys. It is interesting to me that someone would machine these clear lenses, but they did an excellent job IMHO. I am considering drilling and tapping them to accept factory style blinker housings. Then I will put in some amber bulbs and call it a day. I think I will make some housings rather than pay the going rate for repos. On another note, I installed my new AMD fender on the driver's side today. Tomorrow I am going to work on alignment and maybe I'll install my super stock springs. Cheers!
Re: 68 Charger clear hood blinker indicator - stock? [Re: sthemi] #1038564
07/24/11 10:54 AM
07/24/11 10:54 AM
Hatfield,Pa.
bigD Offline
bigD  Offline
Hatfield,Pa.
WRONG.. mine does not have the hood indicators but has the factory block off plugs instead,D
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
Re: 68 Charger clear hood blinker indicator - stock? [Re: bigD] #1038565
07/24/11 12:18 PM
07/24/11 12:18 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Maybe it was froma 70....70 had the hole punched in the hood either way and then the insert plate had the delete plate screwed on OR the blinker mechanism
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: 68 Charger clear hood blinker indicator - stock? [Re: 70cudaproject] #1038566
07/24/11 12:24 PM
07/24/11 12:24 PM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
Yeah- as other's said- not stock.
Looks like a creative way to fix what is a really BAD water leak if they are missing.
Charger Specialites sells replacements:
http://www.chargerspecialties.com/signals.htm
I have used these before and the quality is excellent!
Good Luck,
CC.
Re: 68 Charger clear hood blinker indicator - stock? [Re: bigD] #1038567
07/24/11 05:02 PM
07/24/11 05:02 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I concur
The hoods were punched out for the indicators weather optioned with them or not....like he said metal "block off" plates were installed in place of the lenses....
1MYTGTX
