Original seat height position, E bodies. #1038476
07/23/11 02:56 PM
07/23/11 02:56 PM
Walmart parking lot
yorker Offline OP
Drugs are bad
yorker  Offline OP
Drugs are bad
Walmart parking lot
I was thinking about buying a 70 Challenger because I think they are cool. I used to own one in 1974.
Now when looking in them and sitting in them, the seating height or lack of seems so unusual.
Almost like sitting in a go kart.
I also feel like am sitting in a deep bath tub as the seat seems very low.
The position of the steering wheel and all seem off because of this.
Do any of you e body owners have problems with this set up.
Does not look to be designed with comfort in mind.
( SHONEN KNIFE ) MAKING THE WORLD A BETTER PLACE. ONE SONG, ONE CONCERT AT A TIME FOR OVER 36 YEARS!!
https://www.youtube.com/user/SHONENKNIFETV
Re: Original seat height position, E bodies. [Re: yorker] #1038477
07/23/11 03:05 PM
07/23/11 03:05 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
To me, after driving newer trans ams and other sporty cars that had the seats that sat low, I really don't notice nor does it bother me. Now if you go from a truck to an e-body, then it's very noticeable.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Original seat height position, E bodies. [Re: Silver70] #1038478
07/23/11 03:16 PM
07/23/11 03:16 PM
Walmart parking lot
yorker Offline OP
Drugs are bad
yorker  Offline OP
Drugs are bad
Walmart parking lot
I suppose that is the issue, I have been driving Rams the last 30 years.
I remember in 1974 I thought it was cool. I was 21 then, now 58
Re: Original seat height position, E bodies. [Re: yorker] #1038479
07/23/11 03:18 PM
07/23/11 03:18 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That's why you old guys like B body's.
Re: Original seat height position, E bodies. [Re: Challenger 1] #1038480
07/23/11 04:10 PM
07/23/11 04:10 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Find and add a six way seat adjuster, it makes a world of difference.
Re: Original seat height position, E bodies. [Re: yorker] #1038481
07/23/11 05:32 PM
07/23/11 05:32 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I find mine to be too high, and not slide back far enough. This puts the steering wheel too close for my liking. A bit of recline would be nice to have.
If the back of the seat mounts could be lowered a half inch or so, I think it would be perfect. By the looks of it, the floor-pan will have to sectioned because the seat tracks are flat with the floor.
Mo' Farts
Moderated by "tbagger".
Re: Original seat height position, E bodies. [Re: Alaskan_TA] #1038482
07/23/11 07:09 PM
07/23/11 07:09 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Six way is the only way, fortunately my challenger has one. I feel like Im sitting at a kitchen table driving my dads Barracuda without one.
Re: Original seat height position, E bodies. [Re: wally426ci] #1038483
07/23/11 07:27 PM
07/23/11 07:27 PM
Red Lion, PA USA
scamper340 Offline
scamper340  Offline
Red Lion, PA USA
I felt the same way about my Scamp. The previous owner added '70 highback buckets and they always felt a little low compared to my '69 Swinger bench seat. When I redid the seats in the Scamp, the spacers were missing from under the seat rails. They make reproductions now so I installed them when I refinished the tracks. I also had new foam installed when I had the seats recovered. Between the foam and the spacers, it probably added a good 3 inches. It feels totally different sitting in it now, like a new car. I don't know if you can see much of a difference in the pics, but you can definitely feel it.
Before:
After:
Re: Original seat height position, E bodies. [Re: scamper340] #1038484
07/23/11 07:29 PM
07/23/11 07:29 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
It happens. Before I rode my Stealth (which really sits low) I was driving my mom's Mitsubishi Montero and once I sat in that Stealth I felt like I was shrinking. Even when I sat in my friends 97 Eclpise a couple months ago (stock height) compared to my 2011 Scion tc, I felt I was low. Then I got used to it.
Re: Original seat height position, E bodies. [Re: MuuMuu101] #1038485
07/23/11 08:41 PM
07/23/11 08:41 PM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
Are the spacers under the seat tracks? Most are broken and missing by now.
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: Original seat height position, E bodies. [Re: Challenger 1] #1038486
07/24/11 10:56 AM
07/24/11 10:56 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
depends if the padding is worn flat also...but, you are correct that the steering wheel and seat position seems a little off.. it's worse when you have a bench seat...ask me how I know....
Re: Original seat height position, E bodies. [Re: AARCONV] #1038487
07/24/11 11:12 AM
07/24/11 11:12 AM
IN
ahy Offline
ahy  Offline
IN
I'm running a '70E. The basic design of the car sets the driver low. With the seat set up correctly, the wheel and pedals seem to work fine however. Mine originally had the OE high back buckets. When I got the car they had new foam and covers. Height was OK but I found them to be lacking in both lateral support and back support.
I installed a set of Scat "Ralley" buckets (Summit). Scat makes a mounting bracket specifically for the E which has 3 mounting height settings. I used the lowest setting to get the driving position - especially the seat height to steering wheel relationship - I wanted.
Re: Original seat height position, E bodies. [Re: ahy] #1038488
07/24/11 11:50 AM
07/24/11 11:50 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
I'm only 5'5" so I literally can't see a damn thing out of a typical e body . Very uncomfortable, but the looks are undeniable....
MB
Re: Original seat height position, E bodies. [Re: HPMike] #1038489
07/24/11 12:15 PM
07/24/11 12:15 PM
IN
ahy Offline
ahy  Offline
IN
Another comment in setting up driving position. Steering wheel height is somewhat adjustable by shimming the top mounting bracket. The U bracket that clamps the upper part of the column to the dash frame has long studs and often has shims under the bracket. Add or remove shims (washers) to get the steering wheel where you want it. When you do this, it will also be necessary to loosen and adjust the mounting plate on the firewall to maintain column and steering shaft alignment. The floor plate is adjusted so the steering shaft is centered in the column tube where it enters the engine compartment.
Re: Original seat height position, E bodies. [Re: HPMike] #1038490
07/24/11 02:47 PM
07/24/11 02:47 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
MB
Tha picture is bad ass.
Re: Original seat height position, E bodies. [Re: wally426ci] #1038491
07/24/11 06:14 PM
07/24/11 06:14 PM
Raleighwood
2Bad360sfromNC Offline
Raleighwood
I wonder if anyone has devised a way to recline the e-body seats without permanently messing them up.
1968 Charger project. I don't have a fender tag or a buildsheet, so it's getting a 440. Help me decide on a color--most everything looks great! (NOT white. My Challenger is white. Need some variety :D)
1974 Challenger 360
2012 Challenger R/T
1991 Dakota 5.2
Re: Original seat height position, E bodies. [Re: 2Bad360sfromNC] #1038492
07/24/11 11:45 PM
07/24/11 11:45 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I used the stock seat mounting spacers under the front only. It did help recline it a bit.
Re: Original seat height position, E bodies. [Re: jbc426] #1038493
07/25/11 10:38 AM
07/25/11 10:38 AM
Frederiction. New Brunswick ,C...
RTshaker Offline
RTshaker  Offline
Did E bodies have mounting spacers from the factory ????
Re: Original seat height position, E bodies. [Re: RTshaker] #1038494
07/25/11 12:14 PM
07/25/11 12:14 PM
Raleighwood
Raleighwood
I just see the tracks with the studs sticking out on mine. I guess I could shim the front studs with a few washers and see how big a difference that makes.
1974 Challenger 360
2012 Challenger R/T
1991 Dakota 5.2
Re: Original seat height position, E bodies. [Re: 2Bad360sfromNC] #1038495
07/25/11 12:18 PM
07/25/11 12:18 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I picked up a couple sets from RT Specialties or Dale's 'Cuda Shop or somewhere.
My seats have new foam. I wish they sat a bit lower as my head is up close to the headliner, but with the spacers adding to the the recline, i'm used to it.
