Badly Stamped VIN Sequence #'s On Engines & Transmision #1038091
07/22/11 07:52 PM
07/22/11 07:52 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
Check this one out! I'd call it a factory mis stamp, appears that this one was put on with a pneumatic stamping gun that went all "Machine Gun Kelly" on this trannys A**
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: ScottSmith_Harms] #1038092
07/22/11 08:09 PM
07/22/11 08:09 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
"Let Go Of The Trigger Bob"
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: Morty426] #1038093
07/22/11 09:44 PM
07/22/11 09:44 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Great photo Scott, if it is yours I would love to use it on the factory error pages of HH.
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: Alaskan_TA] #1038094
07/22/11 09:53 PM
07/22/11 09:53 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes it's mine, go right ahead!
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: ScottSmith_Harms] #1038095
07/22/11 10:01 PM
07/22/11 10:01 PM
My '63 core support:
Hard to see but the first one was mis-stamped so they stamped it again!
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision #1038096
07/22/11 10:03 PM
07/22/11 10:03 PM
My '71 Barracuda, despite being all orignal paint and never having been apart, had no VIN anywhere on the core support.
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: ScottSmith_Harms] #1038097
07/22/11 10:03 PM
07/22/11 10:03 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
9B425129
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: 6bblgt] #1038098
07/22/11 10:32 PM
07/22/11 10:32 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
...and that's why he's called the Photo Detective...
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: topside] #1038099
07/22/11 11:15 PM
07/22/11 11:15 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The bottoms of the 3s 5s & 9s are similar , so those are "best guesses".
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: 6bblgt] #1038100
09/16/11 12:38 PM
09/16/11 12:38 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Heres my Duster 340's trans. Barry, feel free to use it if you'd like. Anyone see a 115059 on there??
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: NV69B7RR] #1038101
09/16/11 01:09 PM
09/16/11 01:09 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
It's there, just looks like
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: 6bblgt] #1038102
09/16/11 02:04 PM
09/16/11 02:04 PM
Salinas, California
1970Cuda Offline
super street
1970Cuda  Offline
super street
Salinas, California
How would a potential buyer of your car be able to verify that an engine block or transmission is numbers matching if they're so messed up and unreadable?
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: 1970Cuda] #1038103
09/16/11 02:18 PM
09/16/11 02:18 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
This the original 18 spline to a '71 GTX I owned. Not as bad as the others posted though
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: 1970Cuda] #1038104
09/16/11 02:21 PM
09/16/11 02:21 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Very good point.
The block is easy to read fortunately.
As for the trans they'd be in the same shoes I was in...and it didn't matter that much to me since everything else was so original. Talking to the original owner added confidence that it was the original trans. I'll just take a sharpie and write the #'s on it and I plan to leave the #'s as is.
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: NV69B7RR] #1038105
09/16/11 02:41 PM
09/16/11 02:41 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I just saw a 70 Hemi Cuda with numbers stamped on the rough casting right ABOVE the machined pad. Faint but readable.
And... it turned out to be number matching motor, std bore. That owner was OE bearing and all.
I heard of a 69 340 Swinger with number stamped on the oil pan rail lip. They missed the motor entirely.
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: autoxcuda] #1038106
09/16/11 03:05 PM
09/16/11 03:05 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Like this one?
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: 70440+6bbl] #1038107
09/16/11 03:10 PM
09/16/11 03:10 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Like this one?
Yep, but a little closer to the edge.
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: 70440+6bbl] #1038108
09/16/11 09:09 PM
09/16/11 09:09 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Like this one?
Bet I know where you got that picture That's Ken Funks Hemi block.
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: ScottSmith_Harms] #1038109
09/16/11 10:45 PM
09/16/11 10:45 PM
ALABAMA
4406PAKCUDA Offline
4406PAKCUDA  Offline
ALABAMA
Here's a manifold off a early production 70 440-6 Cuda, appears to be dated in 59?
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: 4406PAKCUDA] #1038110
09/17/11 01:17 PM
09/17/11 01:17 PM
Hamburg, Pa.
72 RR DUDE Offline
72 RR DUDE  Offline
Hamburg, Pa.
Here is another strange one. Bought a 1972 B-body from the original owner. It is a 340 with a 4speed. THe trans looks like the ones already posted and the engine has no stamping. The date on the front of the block shows it was done about 3 months before the car was built which is about right. Don't know if it was a warranty block put in before it left the plant or if it was never stamped. The original owner insist's that it is the original drive train. What do you guys think?
