Re: Badly Stamped VIN Sequence #'s On Engines & Transmision
[Re: ScottSmith_Harms]
#1038095
07/22/11 10:01 PM
07/22/11 10:01 PM
My '63 core support:
Hard to see but the first one was mis-stamped so they stamped it again!
#1038096
07/22/11 10:03 PM
07/22/11 10:03 PM
My '71 Barracuda, despite being all orignal paint and never having been apart, had no VIN anywhere on the core support.
[Re: 1970Cuda]
#1038104
09/16/11 02:21 PM
09/16/11 02:21 PM
Posts: 6,005 Reno, Nevada
NV69B7RR
Reno, Nevada
Very good point. The block is easy to read fortunately. As for the trans they'd be in the same shoes I was in...and it didn't matter that much to me since everything else was so original. Talking to the original owner added confidence that it was the original trans. I'll just take a sharpie and write the #'s on it and I plan to leave the #'s as is.
[Re: NV69B7RR]
#1038105
09/16/11 02:41 PM
09/16/11 02:41 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
I just saw a 70 Hemi Cuda with numbers stamped on the rough casting right ABOVE the machined pad. Faint but readable. And... it turned out to be number matching motor, std bore. That owner was OE bearing and all. I heard of a 69 340 Swinger with number stamped on the oil pan rail lip. They missed the motor entirely.
[Re: 70440+6bbl]
#1038107
09/16/11 03:10 PM
09/16/11 03:10 PM
autoxcuda
So Cal
Like this one?
Yep, but a little closer to the edge.
