What size carb?
#1038060
07/22/11 06:46 PM
07/22/11 06:46 PM
Posts: 146 Queensland,Australia
T-bar
I had my car to the chassis dyno yesterday and did some tuning with the current torker manifold and 850 holley and then changed to a victor manifold. With jet changes and the manifold we had just over 30hp increase but the carb air/fuel ratio was not spot on and couldn't fix it. The dyno op decided a bigger carb would definetly help but didn't have any to try. He suggested that i go up to 950cfm and that should be plenty but i thought a 1050cfm would be better in case of future cam upgrades etc. 496 rb 10.5 comp slightly ported eddy performers solid 565"lift 274 duration @50 victor intake gasket matched 727 auto stalls at 4000 3.91 rear gears 295/65/15 tyres So what do you all think or recomend any input is appreciated.
Re: What size carb?
[Re: T-bar]
#1038061
07/22/11 07:25 PM
07/22/11 07:25 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
That many Cubic inches I would definatly go with the 1050.
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: What size carb?
[Re: T-bar]
#1038067
07/22/11 09:49 PM
07/22/11 09:49 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I might think about a 950 so it has a quicker response since you foot brake but on a trans brake I like bigger... how may revs do you plan on Or get a custom carb with a 4150 base but flows in the 1050 to 1100 cfm range
Re: What size carb?
[Re: T-bar]
#1038070
07/22/11 11:48 PM
07/22/11 11:48 PM
Posts: 996 Queens, New York
Harley
Queens, New York
It runs out at about 6000 rpm. I was looking at the Quickfuel Q-950 or the Q-1050 4150 base. The price is only $50 between them but i don't want buy something that isn't going to be right. [/quote
What kind of power did it make?
Re: What size carb?
[Re: T-bar]
#1038073
07/23/11 03:39 AM
07/23/11 03:39 AM
Posts: 2,471 Sydney,Australia
tex013
Sydney,Australia
talk to Patrick,Prosystems.his price is right. personally i don't buy tyre size guff.it is only a factor to set up the dyno.though some 4.10's won't hurt with that cam really i would hope to be making some more power and if it has all gone by 6000 i would be looking at your whole fuel system good luck Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
