Page 2 of 3 1 2 3
Re: build me a bad a$$ small block [Re: sixpackgut] #1035914
07/19/11 04:40 PM
07/19/11 04:40 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
Why not a big block LOL!!!
Re: build me a bad a$$ small block [Re: dragram440] #1035915
07/19/11 04:45 PM
07/19/11 04:45 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I guess he wants to spend a ton of money.
Re: build me a bad a$$ small block [Re: Mr.Yuck] #1035916
07/19/11 04:51 PM
07/19/11 04:51 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
well, at the amount i have spent so far on this small block, i could have built 3 600 hp big blocks which in a 3000 pound car would run a decent number
Re: build me a bad a$$ small block [Re: Mr.Yuck] #1035917
07/19/11 04:53 PM
07/19/11 04:53 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
my engine cost a few grand more then predator heads cost themselves..340 resto block,4" scat crank,4.185 diamond pistons,11.3 compression,and knowledge from ryanj o yea cam is little under 700lift..its a street car also 3.91 gears and all so i paid extra for pac springs...i was gonna try methanol injection to make up for the lack of horsepower being it only made 729hp with a 950carb and only 620lbs of torque..i know yuck is in the bushes reading my combo..lol
Re: build me a bad a$$ small block [Re: fishy340] #1035918
07/19/11 05:00 PM
07/19/11 05:00 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
meth is good because you can run the advance you want on pump gas. P.S. 700 lift and street car don't go together...lol Bushes?? I doon need no steankin' stroker crank.
Re: build me a bad a$$ small block [Re: Mr.Yuck] #1035919
07/19/11 05:02 PM
07/19/11 05:02 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
lol
Re: build me a bad a$$ small block [Re: sixpackgut] #1035920
07/19/11 05:54 PM
07/19/11 05:54 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I got a turn key 600+ horse SB I can sell you for a good price.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: build me a bad a$$ small block [Re: dusturbd340W5] #1035921
07/19/11 06:19 PM
07/19/11 06:19 PM
Charleston
Charleston
Woody, send me a PM
Re: build me a bad a$$ small block [Re: Mr.Yuck] #1035922
07/19/11 07:05 PM
07/19/11 07:05 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
You can say that again.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: build me a bad a$$ small block [Re: pittsburghracer] #1035923
07/19/11 07:20 PM
07/19/11 07:20 PM
SoCal
Brian Hafliger Online content
Brian Hafliger  Online Content
SoCal
How about a 450cid, pump gas, Indy heads done by me, 1250 dominator, pump gas and around 700-720HP for about 15,500.00?
It won't be a street cam but it will make the power. 48° block, Charlies pan, etc....
Basicly our 800Hp build on pump gas and different cam.
Brian
Brian Hafliger
Re: build me a bad a$$ small block [Re: Brian Hafliger] #1035924
07/19/11 07:29 PM
07/19/11 07:29 PM
Charleston
Charleston
Brian
Brian, where would peak HP be on that combo?
Re: build me a bad a$$ small block [Re: Brian Hafliger] #1035925
07/19/11 07:33 PM
07/19/11 07:33 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Just buy a nationwide engine. Guarateed 840 hp for less than 8k.......
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: build me a bad a$$ small block [Re: sixpackgut] #1035926
07/19/11 07:36 PM
07/19/11 07:36 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Hey Brian.....Dont you have a 400+" SB with around 620hp and pump gas forsale??
Re: build me a bad a$$ small block [Re: DemonDust] #1035927
07/19/11 07:37 PM
07/19/11 07:37 PM
Charleston
Charleston
not a pump gas street car engine
Re: build me a bad a$$ small block [Re: sixpackgut] #1035928
07/19/11 07:47 PM
07/19/11 07:47 PM
Renton Washington
Triple Threat Offline
Renton Washington
I thought you were putting the Gen 3 hemi in the challenger?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: build me a bad a$$ small block [Re: MIKES_DUSTER] #1035929
07/19/11 08:03 PM
07/19/11 08:03 PM
SoCal
SoCal
Yes, but it would seem he wants more than that?
Peak Hp would be around 7200-7400rpm. I can bring the rpm down for more TQ in exchange for HP and rpm range.
Brian Hafliger
Re: build me a bad a$$ small block [Re: Triple Threat] #1035930
07/19/11 08:04 PM
07/19/11 08:04 PM
Charleston
Charleston
i am. i got sick of hearing about small blocks so i wanted a good laugh before i went on vacation.
i am thinking i will have 8k in my hemi when its done and it will make 1000 hp
and someone could build my bb for under 10k and make over 700
i think if someone was to build a modern cnc'd procomp headed 400 based big block, 800hp could be had for 9k
Re: build me a bad a$$ small block [Re: sixpackgut] #1035931
07/19/11 08:08 PM
07/19/11 08:08 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
does the pretty tunnel ram come with the bb ur selling? or is it there to help make the 700 hp u claim to have?
Re: build me a bad a$$ small block [Re: Brian Hafliger] #1035932
07/19/11 08:17 PM
07/19/11 08:17 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Brian
that's a TON of money. WHy not just use a low compression 360 and a blower and be done for half? less cam, less stall and less gear required and you can DRIVE IT
Re: build me a bad a$$ small block [Re: fishy340] #1035933
07/19/11 08:18 PM
07/19/11 08:18 PM
Charleston
Charleston
would your expensive big small block push my Challenger to low 20s? i dont think so unless your running 5.90. maybe you are
i just want to say that i respect Leon, B3 and Brian for how well their cars run
Andy, i think you have a complex about something
Page 2 of 3 1 2 3
