Re: build me a bad a$$ small block
[Re: dragram440]
#1035915
07/19/11 04:45 PM
07/19/11 04:45 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Why not a big block LOL!!!
I guess he wants to spend a ton of money.
[Re: fishy340]
#1035918
07/19/11 05:00 PM
07/19/11 05:00 PM
Mr.Yuck
Brookeville, Md
my engine cost a few grand more then predator heads cost themselves..340 resto block,4" scat crank,4.185 diamond pistons,11.3 compression,and knowledge from ryanj o yea cam is little under 700lift..its a street car also 3.91 gears and all so i paid extra for pac springs...i was gonna try methanol injection to make up for the lack of horsepower being it only made 729hp with a 950carb and only 620lbs of torque..i know yuck is in the bushes reading my combo..lol
meth is good because you can run the advance you want on pump gas. P.S. 700 lift and street car don't go together...lol Bushes?? I doon need no steankin' stroker crank.
[Re: Mr.Yuck]
#1035919
07/19/11 05:02 PM
07/19/11 05:02 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
lol
[Re: dusturbd340W5]
#1035921
07/19/11 06:19 PM
07/19/11 06:19 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
well, at the amount i have spent so far on this small block, i could have built 3 600 hp big blocks which in a 3000 pound car would run a decent number
I got a turn key 600+ horse SB I can sell you for a good price.
Woody, send me a PM
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: pittsburghracer]
#1035923
07/19/11 07:20 PM
07/19/11 07:20 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
How about a 450cid, pump gas, Indy heads done by me, 1250 dominator, pump gas and around 700-720HP for about 15,500.00?
It won't be a street cam but it will make the power. 48° block, Charlies pan, etc....
Basicly our 800Hp build on pump gas and different cam. Brian
Brian Hafliger
[Re: Brian Hafliger]
#1035924
07/19/11 07:29 PM
07/19/11 07:29 PM
sixpackgut
Charleston
Brian, where would peak HP be on that combo?
#1035932
07/19/11 08:17 PM
07/19/11 08:17 PM
Mr.Yuck
Brookeville, Md
that's a TON of money. WHy not just use a low compression 360 and a blower and be done for half? less cam, less stall and less gear required and you can DRIVE IT
