Max you can cut Edelbrock Head? #1034447
07/17/11 08:34 PM
07/17/11 08:34 PM
Anonymous OP
Anonymous OP
What is the max you can cut off an 84cc Edelbrock big block head--who has done what?
Re: Max you can cut Edelbrock Head? [Re: ] #1034448
07/17/11 08:38 PM
07/17/11 08:38 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
..and let us hear what each cut is worth in CC reduction ..
Re: Max you can cut Edelbrock Head? [Re: ] #1034449
07/17/11 08:52 PM
07/17/11 08:52 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Just a guess, but I think 0.5 to 0.6cc reduction for every 0.010" cut? The open part of the chamber is about 1/2 the diameter of the chamber? Not sure how thick the heads are to know how much could be milled off them?
Re: Max you can cut Edelbrock Head? [Re: 451Mopar] #1034450
07/17/11 09:22 PM
07/17/11 09:22 PM
Auburn, Indiana
The Duster Offline
The Duster  Offline
Auburn, Indiana
Re: Max you can cut Edelbrock Head? [Re: The Duster] #1034451
07/17/11 10:14 PM
07/17/11 10:14 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
https://board.moparts.org/ubbthreads/show...page=0&vc=1
Cool,
I don't have to re type it all
Re: Max you can cut Edelbrock Head? [Re: WILD BILL] #1034452
07/17/11 10:32 PM
07/17/11 10:32 PM
Anonymous OP
Anonymous OP
Thanks gang! I am helping on a 400 stock stroke that needs more CR so I was planning on shooting for that 65cc # and just cutting the intake to fit--would have been good to go with domes but bottom was already on the table
Re: Max you can cut Edelbrock Head? [Re: ] #1034453
07/17/11 10:54 PM
07/17/11 10:54 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
60929 head. Now 72cc from 84cc. Believe it was .060 cut.
Michael
Re: Max you can cut Edelbrock Head? [Re: SILVER67] #1034454
07/17/11 11:40 PM
07/17/11 11:40 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
I had the original Edelbrock heads (when they first came out) on a 440. I can't remember if those original sets were a 88 or 84cc chamber. But... I do remember that I had them milled .038" which became a 77cc chamber.
-dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Max you can cut Edelbrock Head? [Re: 451Mopar] #1034455
07/18/11 02:51 AM
07/18/11 02:51 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I was way off. I went back and looked at a picture of the RPM heads, and the quench pad area is alot smaller than I thought (I was thinking chamber was more like the victor heads.)
From photos it looks like the quench area is only about 15% of the chamber, so if you had the estimated bore size (4.4"?) minus the 15% (3.74" equivlent bore?) then a 0.010" cut would be 1.8cc, and each cut would increase the quench area resulting in slightly less cc's (maybe 0.1cc) removed per cut? With these numbers it would take a cut of about 0.110" to take the 84cc heads to about 65cc?
Re: Max you can cut Edelbrock Head? [Re: 451Mopar] #1034456
07/18/11 12:12 PM
07/18/11 12:12 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
The first cut of my heads we took off .090" and they measured 64.6 cc's
Re: Max you can cut Edelbrock Head? [Re: WILD BILL] #1034457
07/19/11 12:56 AM
07/19/11 12:56 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Was that the 88cc open chamber heads, or the 84cc closed chamber heads? I'm just trying to make sense of the numbers. If you started with the closed chamber 84cc heads, the closed part of the chamber (quench area) would have to only be about 7% of the chamber area? The numbers do come pretty close if you started with the 88cc open chamber heads?
Re: Max you can cut Edelbrock Head? [Re: 451Mopar] #1034458
07/19/11 01:19 AM
07/19/11 01:19 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
They are the 84 cc heads.
Re: Max you can cut Edelbrock Head? [Re: WILD BILL] #1034459
07/19/11 02:08 AM
07/19/11 02:08 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'll take your word for it then since you have done that, and I don't have RPM heads to actually go measure how wide the chambers are.
Re: Max you can cut Edelbrock Head? [Re: 451Mopar] #1034460
07/19/11 09:44 AM
07/19/11 09:44 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
