Anyone picked up power going to an MSD box? #1033160
07/15/11 08:30 PM
07/15/11 08:30 PM
oberlin, Ohio
Rapid340 Offline OP
Rapid340  Offline OP
oberlin, Ohio
Has anyone found any power (or loss) going from a good mopar chrome or gold ignition to an MSD box in a higher compression motor? I am thinking the MSD box delivers higher voltage to the plugs but less duration.
I know one guy who made the change and doesnt think he gained anything (other than better idle) in a high compression HEMI
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Anyone picked up power going to an MSD box? [Re: Rapid340] #1033161
07/15/11 09:33 PM
07/15/11 09:33 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
No gain with us.The gold box works great!
Nautilus Racing-
Re: Anyone picked up power going to an MSD box? [Re: Rapid340] #1033162
07/15/11 10:01 PM
07/15/11 10:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I went from the gold box to a 7-AL and had 0 change
Re: Anyone picked up power going to an MSD box? [Re: MR_P_BODY] #1033163
07/15/11 11:10 PM
07/15/11 11:10 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I went from a Mallory dual point distributor to an pro billet and a msd 6-al and didn't pick up .001
Re: Anyone picked up power going to an MSD box? [Re: rowin4] #1033164
07/15/11 11:23 PM
07/15/11 11:23 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
0 gain. idled better though
Re: Anyone picked up power going to an MSD box? [Re: Rapid340] #1033165
07/15/11 11:24 PM
07/15/11 11:24 PM
Az
Crizila Offline
Crizila  Offline
Az
MSD stands for Multi Spark Discharge = longer spark duration. Voltage "could" be higher also. If your existing ignition is working well with plenty of reserve and your A/F ratio is in the ball park you will see little difference.
Fastest 300
Re: Anyone picked up power going to an MSD box? [Re: Crizila] #1033166
07/15/11 11:26 PM
07/15/11 11:26 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
brad h did see a gain at the track, on the same day with a coil change
Re: Anyone picked up power going to an MSD box? [Re: Crizila] #1033167
07/15/11 11:28 PM
07/15/11 11:28 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
below 3000 rpms
Re: Anyone picked up power going to an MSD box? [Re: sixpackgut] #1033168
07/15/11 11:32 PM
07/15/11 11:32 PM
rowin4 Offline
rowin4  Offline
Idle? is that below 5000 rpm? Don't see much time below 7000
Re: Anyone picked up power going to an MSD box? [Re: Rapid340] #1033169
07/15/11 11:40 PM
07/15/11 11:40 PM
I switch from a early Mopar Chrome box race ignition with the blue heat sink and the proper Accel race coil to a MSD 404B and the special Mallory race coil, Pt# 28880, in my old 1970 hemi stocker, it started better cold, it idled better cold and it ran better in high gear in the summer when the L.A. basin was smogged in The spark plugs lasted forever also I don't remember exactly how much better, probally close to 3 MPH in the summer That nose heavy car(2160 lbs on the front tires, 1280 on the rear with no driver and a half tank of gas ) was a turd leaving the starting line, 4 speed on nine inch tires They call that getting experience I have used the MSD race boxes ever since, none of the street and strip 5 or 6 sereis boxes As already alluded to, if you have enough spark to light the fire, adding additional spark will not give measurable results, usually I also ended up opening the spark plug gap at the same time that I switch boxes, went from .035 to .090 I later went back to .045 with the races boxes and resitor wires and resitor spark plugs The 7 sereies boxes need the resitor wires, the earleir 404 race boxes didn't
