Letting a stock 727 shift itself in an 11 second car??? #1032960
07/15/11 02:32 PM
07/15/11 02:32 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
I was thinking I read or heard somewhere that there is a higher risk of transmission failure if you just leave it in drive and let it shift. Any merit to this or did I dream it? Car is a 3500lb Cuda running mid/low 11s with a tight 10" converter. Going racing tonight and the plan is to let it shift itself for consistency sake. Any thoughts?
Re: Letting a stock 727 shift itself in an 11 second car??? [Re: OA5599] #1032961
07/15/11 02:35 PM
07/15/11 02:35 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Did it a lot with a 12 second Mopar. No problems with reliability or consistency.
Getting old just means you were smarter than some and luckier than others.
Re: Letting a stock 727 shift itself in an 11 second car??? [Re: OA5599] #1032962
07/15/11 02:36 PM
07/15/11 02:36 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
if you have the kick-dow....err throttle pressure linkage set-up I don't see why you couldn't.
Coming soon!!!!
Re: Letting a stock 727 shift itself in an 11 second car??? [Re: Mr.Yuck] #1032963
07/15/11 02:57 PM
07/15/11 02:57 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
...a higher UPshift gov ...and a tad more line-pressure .. been-there ..done-that ..
Re: Letting a stock 727 shift itself in an 11 second car??? [Re: OA5599] #1032964
07/15/11 03:09 PM
07/15/11 03:09 PM
NC
440Jim Offline
440Jim  Offline
NC
One thing to consider is that while in "Drive" and sitting at the starting line, the trans will be in 1st gear without applying the rear (low) band. If something happens, and the driver decides/needs to lift the throttle; they need to be careful how they reapply the throttle if driving speed would result in the trans going/staying into 1st gear which would reload the sprag (not recommended).
The proper burnout procedure for the stock valve body is also recommended.
Re: Letting a stock 727 shift itself in an 11 second car??? [Re: OA5599] #1032965
07/15/11 03:13 PM
07/15/11 03:13 PM
Trans. fluid temps. may affect the shifting RPM when it gets hotter, if you go rounds I have seen my converter do different stalls with cold temps. versus hot fluid when going rounds
Re: Letting a stock 727 shift itself in an 11 second ca [Re: 440Jim] #1032966
07/15/11 03:19 PM
07/15/11 03:19 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Letting a stock 727 shift itself in an 11 second car??? [Re: Cab_Burge] #1032967
07/15/11 03:22 PM
07/15/11 03:22 PM
Florida STAYcation
Florida STAYcation
Trans. fluid temps. may affect the shifting RPM when it gets hotter, if you go rounds I have seen my converter do different stalls with cold temps. versus hooter fluid when going rounds
.... ....did you get that ATF with some of those tasty wings ? ..
Re: Letting a stock 727 shift itself in an 11 second car??? [Re: BeEtLeJuIcE !] #1032968
07/16/11 12:16 PM
07/16/11 12:16 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Doc beat me to it! Thinking of bad puns about hooter fluid on your dipstick! Jim, how about telling everyone the proper procedure for a stock VB? I could use a brush up.
Re: Letting a stock 727 shift itself in an 11 second car??? [Re: Lee446] #1032969
07/16/11 01:03 PM
07/16/11 01:03 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
First rule of racing a stock vb 727;
If the tranny is in first gear, your shifter should be in first gear
An automatic will start out in low regardless of shifter position(its not a c6!) so you better start out in low position...
Re: Letting a stock 727 shift itself in an 11 second car??? [Re: OA5599] #1032970
07/16/11 06:50 PM
07/16/11 06:50 PM
NW Indiana USA
727specialist Offline
NW Indiana USA
I did it for a year in a 11.90 car with no real problems.
The bad part is the 1/2 shift in the water box. When I went through the trans the fingers for the overrunning clutch springs were always beat up and bent. So you are taking your chances there.
When I went manual I got more consistent ETs
Re: Letting a stock 727 shift itself in an 11 second car??? [Re: BeEtLeJuIcE !] #1032971
07/16/11 08:17 PM
07/16/11 08:17 PM
Savannah, GA
mopar400 Offline
mopar400  Offline
Savannah, GA
Ran mine like this for years. Very reliable. I think the trans. has 4-5 seasons on it. I use to race Sat. and Sunday for 2-3 of those yrs. It has a lot of rounds! I just service it and keep the bands adjusted. Consistency was pretty good. My cars been sitting for about 6 years. I'm thinking about going manual on a new transmission just to change it up this time.
1965 Fury II 1970 Challenger 440, 509 cam, 11:1 w/ 452 iron heads, 6.99 1/8, 11.29@ 120mph 1/4 (1999 Magnolia Drag strip track champion) 1992 Jeep XJ Crawler
Re: Letting a stock 727 shift itself in an 11 second car??? [Re: mopar400] #1032972
07/16/11 08:22 PM
07/16/11 08:22 PM
Savannah, GA
mopar400 Offline
mopar400  Offline
Savannah, GA
Re: Letting a stock 727 shift itself in an 11 second car??? [Re: OA5599] #1032973
07/16/11 08:57 PM
07/16/11 08:57 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I leave mine in drive. I've noticed, like Cab said, the shift rpm drifts up a bit from the first run to the second run when it gets hotter, then stays about the same from there for the rest of the day. I notice it more in the cool days of late fall more. If I warmed everything up better it might not happen.
I don't know the answer to your question. But I have a steel drum and ultimate sprag and will probably get a blanket before I go back out again.
Re: Letting a stock 727 shift itself in an 11 second car??? [Re: BSB67] #1032974
07/16/11 09:07 PM
07/16/11 09:07 PM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
I have been doing it for about 15 years now. I have a transmission cooler. I try to make sure that the engine temp. is about 140 degrees. I do my burnout in #2 and then make sure the factory shifter is in drive before I stage. It has worked fine for me.
Re: Letting a stock 727 shift itself in an 11 second car??? [Re: BSB67] #1032975
07/16/11 09:29 PM
07/16/11 09:29 PM
Florida STAYcation
Florida STAYcation
I leave mine in drive. I've noticed, like Cab said, the shift rpm drifts up a bit from the first run to the second run when it gets hooter,
Yeah ... me thimks CB has found the latest-TRIX ... I will have to see if they sell that ATF by the 5 gal pail ..
Re: Letting a stock 727 shift itself in an 11 second car??? [Re: OA5599] #1032976
07/17/11 04:30 AM
07/17/11 04:30 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
I used to leave with the shifter in manual low, then upshift into D at about the 60' clocks before the car would normally shift itself. It give the roller clutch the protection of the low/rev band on the launch, and the consistency of the governor controlled upshifts.
I used to leave with the shifter in manual low, then upshift into D at about the 60' clocks before the car would normally shift itself. It gives the roller clutch the protection of the low/rev band on the launch, and the consistency of the governor controlled upshifts.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
