Re: Letting a stock 727 shift itself in an 11 second car???
[Re: OA5599]
#1032961
07/15/11 02:35 PM
07/15/11 02:35 PM
Posts: 5,160 Texas
dannysbee
Texas
Did it a lot with a 12 second Mopar. No problems with reliability or consistency.
Getting old just means you were smarter than some and luckier than others.
[Re: OA5599]
#1032965
07/15/11 03:13 PM
07/15/11 03:13 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
Trans. fluid temps. may affect the shifting RPM when it gets hotter, if you go rounds I have seen my converter do different stalls with cold temps. versus hot fluid when going rounds
[Re: 440Jim]
#1032966
07/15/11 03:19 PM
07/15/11 03:19 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
One thing to consider is that while in "Drive" and sitting at the starting line, the trans will be in 1st gear without applying the rear (low) band.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: Cab_Burge]
#1032967
07/15/11 03:22 PM
07/15/11 03:22 PM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Trans. fluid temps. may affect the shifting RPM when it gets hotter, if you go rounds I have seen my converter do different stalls with cold temps. versus hooter fluid when going rounds
.... ....did you get that ATF with some of those tasty wings ? ..
[Re: BSB67]
#1032975
07/16/11 09:29 PM
07/16/11 09:29 PM
dOc !
Florida STAYcation
I leave mine in drive. I've noticed, like Cab said, the shift rpm drifts up a bit from the first run to the second run when it gets hooter,
Yeah ... me thimks CB has found the latest-TRIX ... I will have to see if they sell that ATF by the 5 gal pail ..
