Slow me down? #1032487
07/14/11 01:57 PM
07/14/11 01:57 PM
DES MOINES IOWA
P
PARTSMAN440 Offline OP
P
DES MOINES IOWA
Well I finally got to race with my newly installed Alston ladderbar and coilover setup and I'm red by .06 to .08 I leave on the bottom yellow. I made 6 passes Sat night and the car is very consistant, just red. How can I slow the car's reaction time by just the amount I'm red.
Re: Slow me down? [Re: PARTSMAN440] #1032488
07/14/11 01:59 PM
07/14/11 01:59 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Transbrake or footbrake?
Re: Slow me down? [Re: PARTSMAN440] #1032489
07/14/11 02:00 PM
07/14/11 02:00 PM
tboomer Online work
tboomer  Online Work
Tim...Me and Jimmy just discussed this...What rpms are you leaving at? I have a 3400 in on the two-step and have been going a tiny bit red..He said to try a 3200... How do you like that Alston set up?
Re: Slow me down? [Re: tboomer] #1032490
07/14/11 02:26 PM
07/14/11 02:26 PM
DES MOINES IOWA
P
P
DES MOINES IOWA
I run a transbrake. I have been leaving at 3200.
Re: Slow me down? [Re: PARTSMAN440] #1032491
07/14/11 02:28 PM
07/14/11 02:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Lower the RPM and lower the front tire pressure
Re: Slow me down? [Re: PARTSMAN440] #1032492
07/14/11 02:29 PM
07/14/11 02:29 PM
tboomer Online work
tboomer  Online Work
Maybe take a couple of pounds of air outta the front tires? You coming up to the circus next Saturday? >>>>>None for you if you plan on being on a golf cart!!
Re: Slow me down? [Re: tboomer] #1032493
07/14/11 02:35 PM
07/14/11 02:35 PM
DES MOINES IOWA
P
P
DES MOINES IOWA
Hello Ted. The Alston setup is the shiznit. Ilove the way the car leaves now, just too quick. I didnt try to change the way I leave. I just wanted some seat time. Jim said to buy a ajustable tbrake switch.
Re: Slow me down? [Re: PARTSMAN440] #1032494
07/14/11 02:38 PM
07/14/11 02:38 PM
tboomer Online work
tboomer  Online Work
Not a bad idea...I like mine on the steering wheel but who makes an adjustable for that? Also if you are going to change out your heads next year,I may know of a set of Stage VIs...
Re: Slow me down? [Re: tboomer] #1032495
07/14/11 02:44 PM
07/14/11 02:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Biondo makes a nice button I use on the wheel... its
suppose to change .3 on the button(I dont see .3) but
it works well
Re: Slow me down? [Re: MR_P_BODY] #1032496
07/14/11 04:20 PM
07/14/11 04:20 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Shallow stage if not already doing it.Try a 3000 chip if no luck go to a 2800.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Slow me down? [Re: PARTSMAN440] #1032497
07/14/11 04:46 PM
07/14/11 04:46 PM
Can you block the two top bulbs off so you can't see them How about sun glasses or shooting glasses? Maybe a combination of things like lower front tire pressure, stiffer front shock settings, less stiff rear shock settings, taller front tires, add weight to the rear of the car or ?
Re: Slow me down? [Re: Cab_Burge] #1032498
07/14/11 05:24 PM
07/14/11 05:24 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
shoot let me tune it, i'll slow you down by at least .5
