Re: Slow me down?
[Re: PARTSMAN440]
#1032488
07/14/11 01:59 PM
07/14/11 01:59 PM
Posts: 2,933 A shed in England
Tig
A shed in England
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: Slow me down?
[Re: PARTSMAN440]
#1032491
07/14/11 02:28 PM
07/14/11 02:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I run a transbrake. I have been leaving at 3200.
Lower the RPM and lower the front tire pressure
Re: Slow me down?
[Re: tboomer]
#1032495
07/14/11 02:44 PM
07/14/11 02:44 PM
MR_P_BODY
Not a bad idea...I like mine on the steering wheel but who makes an adjustable for that? Also if you are going to change out your heads next year,I may know of a set of Stage VIs...
Biondo makes a nice button I use on the wheel... its suppose to change .3 on the button(I dont see .3) but it works well
Re: Slow me down?
[Re: MR_P_BODY]
#1032496
07/14/11 04:20 PM
07/14/11 04:20 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Shallow stage if not already doing it.Try a 3000 chip if no luck go to a 2800.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
Re: Slow me down?
[Re: PARTSMAN440]
#1032497
07/14/11 04:46 PM
07/14/11 04:46 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
Can you block the two top bulbs off so you can't see them How about sun glasses or shooting glasses? Maybe a combination of things like lower front tire pressure, stiffer front shock settings, less stiff rear shock settings, taller front tires, add weight to the rear of the car or ?
