How to free siezed idle mixture screw Thermoquad??? #1031982
07/13/11 02:59 PM
07/13/11 02:59 PM
Ky
jt4406 Offline OP
jt4406  Offline OP
Ky
Doing a basic rebuild on a Thermoquad for a friend. Carb has been sitting unused for years, but covered the whole time. Looked pretty nice inside and out but left idle mixture screw is siezed up in the base. I have tried gently working it back and forth with a small pair of vicegrips, gentle tapping with a hammer, a heatgun, PB Blaster, WD 40, so far nothing has made it budge. I fear it will break off if I force it more. Anyone got a secret method that WORKS??!!
TIA
Jess
Yeah, it's hopped up to over 160...
Re: How to free siezed idle mixture screw Thermoquad??? [Re: jt4406] #1031983
07/13/11 03:06 PM
07/13/11 03:06 PM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
Well- Mopar Rust Penetrant (sp?)- available over the Parts Counter at any Chryler/Dodge/Jeep/Fiat dealer. Used to be called Heat Riser Valve Lubricant. It has a blackish spray. Basically PB Blaster with Graphite in it.
Soak it down- wait OVERNIGHT- and it should came loose.
Never had it fail yet- even on bumper bolts that were 40 yrs old and in a junkyard for 35+ years....
Good Luck,
CC.
Re: How to free siezed idle mixture screw Thermoquad??? [Re: chargincharles] #1031984
07/13/11 03:10 PM
07/13/11 03:10 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I like 3-in-One oil ....and using that with a lite-touch of a propane torch ... should work.
Re: How to free siezed idle mixture screw Thermoquad??? [Re: dOoC] #1031985
07/13/11 03:19 PM
07/13/11 03:19 PM
Under My Car
Mopar_Country Offline
Under My Car
Soak it in a mixture of brake fluid and trans fluid for a while.
Re: How to free siezed idle mixture screw Thermoquad??? [Re: Mopar_Country] #1031986
07/13/11 03:42 PM
07/13/11 03:42 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Or diesel fuel.
