Re: 318 builds
[Re: 1bad318]
#1030322
07/12/11 12:09 AM
07/12/11 12:09 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
No real numbers on mine, so I dont know the output, bit I'd guess it's around 300hp for pretty cheap
Magnum engine, EFI, heads shaved .020, 220 duration cam w .512 lift on a 114 LSA. M1 single plane intake, and headers
With a bigger cam and heads that flow, I bet 400 is reachable... But again, dollar for dollar, start w a 360!!
If you got a 318, use it. If starting fresh, hit the yards for a magnum 5.9 lots of vans, full size trucks, jeeps, and durangos had 5.9s in them. Finding one in a yard should be easy and fairly cheap
**Photobucket sucks**
Re: 318 builds
[Re: moretork03]
#1030324
07/12/11 05:05 AM
07/12/11 05:05 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Poly, LA, or Magnum?
Here is a 318 build I once thought about doing:
318 engine square decked to 9.590" deck height, stock 3.31" stroke and 6.123" length rods. KB Icon 844 forged flatop pistons, 3.950" bore, 0.040" head gasket, approx 11:1 compression with 52cc heads, 0.040-0.042" quench distance. RHS/Indy or Iron ram magnum heads, full ported, would like to see about 300 cfm?, milled to 50-52cc chamber volume. Hughes is about $2K for the heads? 1.6:1 rocker arms, 3/8" pushrods, Comp MM series solid #6589 intake 297/271/0.669", #6588 exhaust 293/267/0.658", 112 lsa, installed around 106 degrees? Edelbrock Victor intake, and holley 950 HP carb. Estimate HP = 574 @ 7,000 RPM, 469 ft/lbs @ 5,500 RPM. Estimate cranking cylinder pressure = 157 psi (intake closing @ 74.5 degrees ABDC.) with the 0.040" quench it should run on pump gas? TTI 1-3/4" step headers.
Re: 318 builds
[Re: 451Mopar]
#1030325
07/12/11 10:41 AM
07/12/11 10:41 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
sounds like a good combo, but I'd guess the simulated power to be ~ 10% high....1.44 lb-ft per CID is very tough to do without a power adder.
Re: 318 builds
[Re: patrick]
#1030326
07/12/11 07:51 PM
07/12/11 07:51 PM
Posts: 4,323 NY NY
340duster340
NY NY
Is this for more of a performanc builde build or more of a budget?
Imo it's worth starting with more cubes always if star all possible...especially since core 360s are pretty cheap.
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
