318 builds #1030319
07/11/11 05:07 PM
07/11/11 05:07 PM
wisconsin usa
moretork03 Offline OP
wisconsin usa
anyone building these small blocks? how much hp can be had?
Re: 318 builds [Re: moretork03] #1030320
07/11/11 05:13 PM
07/11/11 05:13 PM
dogdays Offline
dogdays  Offline
400 hp at least three different ways. Also with that free 318 block (I've been given three) you install a 4" crank for a 390 or so shortblock and stick on a set of 360 or Magnum heads and you're at 400 hp with a bagful of torque.
R.
Re: 318 builds [Re: dogdays] #1030321
07/12/11 12:02 AM
07/12/11 12:02 AM
jacksboro,tn
1bad318 Offline
1bad440
1bad318  Offline
1bad440
jacksboro,tn
if you have a block thats thick enuff,hensley performance can take em to a 4.00 bore and stroke em to a 402 and dyno's at 498 hp with eddy heads and ross pistons.can't recall compression tho.mine makes about 350 hp with ported j heads,.030 over,kb 9.1 flattops and a crane 284/480 cam and air-gap intake with a 650 dp.run low 9.30's in the 1/8 with 2500 convertor and mufflers and 4.56's in the rear in my 3700 lb(with me in it) truck.with more stall and sticky tires,9.0's and maybe 8.90's
Re: 318 builds [Re: 1bad318] #1030322
07/12/11 12:09 AM
07/12/11 12:09 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
No real numbers on mine, so I dont know the output, bit I'd guess it's around 300hp for pretty cheap
Magnum engine, EFI, heads shaved .020, 220 duration cam w .512 lift on a 114 LSA. M1 single plane intake, and headers
With a bigger cam and heads that flow, I bet 400 is reachable... But again, dollar for dollar, start w a 360!!
If you got a 318, use it. If starting fresh, hit the yards for a magnum 5.9 lots of vans, full size trucks, jeeps, and durangos had 5.9s in them. Finding one in a yard should be easy and fairly cheap
**Photobucket sucks**
Re: 318 builds [Re: 70Cuda383] #1030323
07/12/11 12:21 AM
07/12/11 12:21 AM
jacksboro,tn
1bad318 Offline
1bad440
1bad318  Offline
1bad440
jacksboro,tn
i agree.im basing my numbers off my weight and et.plus desktop dyno put around there.just so much fun beatin stangs with a 318 "work truck" as i call it.not bad times for a 12 year old motor i have totally beat the heack out of.
Re: 318 builds [Re: moretork03] #1030324
07/12/11 05:05 AM
07/12/11 05:05 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Poly, LA, or Magnum?
Here is a 318 build I once thought about doing:
318 engine square decked to 9.590" deck height, stock 3.31" stroke and 6.123" length rods.
KB Icon 844 forged flatop pistons, 3.950" bore, 0.040" head gasket, approx 11:1 compression with 52cc heads, 0.040-0.042" quench distance.
RHS/Indy or Iron ram magnum heads, full ported, would like to see about 300 cfm?, milled to 50-52cc chamber volume. Hughes is about $2K for the heads?
1.6:1 rocker arms, 3/8" pushrods,
Comp MM series solid #6589 intake 297/271/0.669", #6588 exhaust 293/267/0.658", 112 lsa, installed around 106 degrees?
Edelbrock Victor intake, and holley 950 HP carb.
Estimate HP = 574 @ 7,000 RPM, 469 ft/lbs @ 5,500 RPM.
Estimate cranking cylinder pressure = 157 psi (intake closing @ 74.5 degrees ABDC.) with the 0.040" quench it should run on pump gas?
TTI 1-3/4" step headers.
Re: 318 builds [Re: 451Mopar] #1030325
07/12/11 10:41 AM
07/12/11 10:41 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
sounds like a good combo, but I'd guess the simulated power to be ~ 10% high....1.44 lb-ft per CID is very tough to do without a power adder.
2017 Grand Cherokee Overland
Re: 318 builds [Re: patrick] #1030326
07/12/11 07:51 PM
07/12/11 07:51 PM
NY NY
3
340duster340 Offline
NY NY
Is this for more of a performanc builde build or more of a budget?
Imo it's worth starting with more cubes always if star all possible...especially since core 360s are pretty cheap.
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
