Re: Lets hear your stupid fast 440 combo's
[Re: MR_P_BODY]
#1029713
07/11/11 04:40 PM
07/11/11 04:40 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
A mild 440 with a decent cam, .640 and a little port work on the heads with a decent converter should do it easy EDIT all it takes is about 420 HP
, Thats all it takes at 3200 lbs. I did it with stock heads & not so decent cam .
[Re: RemCharger]
#1029714
07/11/11 04:53 PM
07/11/11 04:53 PM
Posts: 52,972 Romeo MI
MR_P_BODY
So you could do it with detuned stock 426 ?
Thats all it takes IF you apply the power to the track
[Re: The Sphinx]
#1029719
07/11/11 09:57 PM
07/11/11 09:57 PM
Posts: 43,355 Bend,OR USA
Cab_Burge
Post them up, I'm looking to get 10.90's in a 3000 LBS car
What parameters do you want followed as far as the block, crankshaft, heads, compression, type of gasoline and so on Lots of ways to get things done, some are cheaper than otherrs
[Re: pittsburghracer]
#1029721
07/11/11 11:02 PM
07/11/11 11:02 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
You name the road and its on...
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1029722
07/12/11 12:22 AM
07/12/11 12:22 AM
Posts: 2,928 A tad North of Indy
Blown71X
super gas
super gas
A tad North of Indy
Not stupid fast by any stretch, but 446 stock forged crank 8.3:1 compression 230/236 @ .050 hydro stick Mildly cleaned up Eddys 2" TTI`s EFI 4000 PTC vert 3.54 gear 275 M/T radial 93 pump gas race weight 4130 10.56 at 127 and change Oh...I forgot, 12 PSI of boost Rick
[Re: Blown71X]
#1029724
07/12/11 02:52 AM
07/12/11 02:52 AM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
My first 440 I had in the cuda: .030" over TRW 11.5 to 1 on stock rods and crank (balanced) ATI super damper 915 heads 78cc, 2.14 1.81 valves (mild port work) 1.5 crane roller rockers .590 312 mopar cam M1 single plane with 750 annular discharge holley 1" super sucker 4200 coan convertor 4.56 with 13 x 31 tire Every bit of this stuff was used but the balancer, super sucker, gaskets, bearings, oil pump, and rings. Just cleaned up, honed, valve job, and new paint. Car weighed 3330 with me in it. It went 10.64 in good air, 10.70-low 80's in the heat.
[Re: Blown71X]
#1029725
07/12/11 06:05 AM
07/12/11 06:05 AM
Posts: 2,141 junction city oregon
viperblue72
Rick
#1029726
07/12/11 09:49 AM
07/12/11 09:49 AM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Road???? What the heck are you talking about? What are we going to talk about next. NOS. I love when a guy builds a small block at about 10 times the cost of a big block and still has to add a power adder. My engines are built by ME in MY garage with off the shelf parts.
yea i love when a guy spends 12.000$ on a set of predator heads,in a tube chassis car that weighs 2500lbs and does 8.30's u got an 8.30 car? bring it to etown and watch how many people will race u with small blocks...ps i dont believe u have an 8.30 car either..lol
[Re: fishy340]
#1029727
07/12/11 10:18 AM
07/12/11 10:18 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
My point. You can make a 340 or any SB run it will just cost you a butt load of money. And forget about using one in a 3800 lb B-body. You can run 10's in a heavy b-body w/ a stock stroke 440 w/ good off the shelf heads, small roller or 600ish solid cam, 4000 stall and 4.56's. Small blocks are fine and yeah they can be fast but at what cost? If you are building a bracket car and looking for 10.90's and don't have a deep wallet I'd think the best route to go is w/ a BB. The guy isn't talking about running 8's spinning his junk to 7500. He wants a weekend beater. Shoot I'd bet w/ a decent tune you could get a 440 into the 10's w/ an old school 509 and iron heads.
[Re: Mr.Yuck]
#1029728
07/12/11 10:52 AM
07/12/11 10:52 AM
Posts: 808 mckinney texas
shoebox
mckinney texas
I think to go fast on the cheap =big block Moneys not an object= small block End goals (anyones) can be met with ethier!
[Re: The Sphinx]
#1029729
07/12/11 01:05 PM
07/12/11 01:05 PM
Posts: 150 South Carolina, United States
carolinacuda
440 .30 over TRW 2355's zero deck stock rods and crank hughes solid cam 576/579 dur.252/256 eddy victor int with mighty demon 850 hooker headers 1 7/8 with 3" collect 3' exh 727 trans with crappy TCI 3500 stall 3.91 gears with 275's M/T radials 11.29 @120 mph 74cuda #3650lbs so in a 3000 car should run 10's easy.
