Page 2 of 6 1 2 3 4 5 6
Re: Lets hear your stupid fast 440 combo's [Re: MR_P_BODY] #1029713
07/11/11 04:40 PM
07/11/11 04:40 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
A mild 440 with a decent cam, .640 and a little port
work on the heads with a decent converter should do
it easy
EDIT
all it takes is about 420 HP
, Thats all it takes at 3200 lbs. I did it with stock heads & not so decent cam .
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Lets hear your stupid fast 440 combo's [Re: RemCharger] #1029714
07/11/11 04:53 PM
07/11/11 04:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
it easy
EDIT
So you could do it with detuned stock 426 ?
Thats all it takes IF you apply the power to the track
Re: Lets hear your stupid fast 440 combo's [Re: MR_P_BODY] #1029715
07/11/11 06:46 PM
07/11/11 06:46 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I ran those numbers in 1989 in 3500lbs GTX with 11.5 trw's and an Isky 590 flat tappet 10" converter 3500 rpm stall ported 906 heads. This was a 440 .030 over with a holley street dominator and an 850 double pumper. Old school
Re: Lets hear your stupid fast 440 combo's [Re: Biginchmopar] #1029716
07/11/11 07:56 PM
07/11/11 07:56 PM
okla.
sam64 Offline
sam64  Offline
okla.
i'm guessing that 420 is at the back tire,not flywheel hp.
Re: Lets hear your stupid fast 440 combo's [Re: pittsburghracer] #1029717
07/11/11 09:45 PM
07/11/11 09:45 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
why not smallblock?
Because small blocks are for girls and old people.
Next time I am in pittsburgh I bring my pumpgas smallblock street car and we can run for a little money motor to motor.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Lets hear your stupid fast 440 combo's [Re: 1967dartgt] #1029718
07/11/11 09:50 PM
07/11/11 09:50 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
after your done with em Brad,i'll do the same with my 10" tire stock suspension sb
Re: Lets hear your stupid fast 440 combo's [Re: The Sphinx] #1029719
07/11/11 09:57 PM
07/11/11 09:57 PM
Post them up, I'm looking to get 10.90's in a 3000 LBS car
What parameters do you want followed as far as the block, crankshaft, heads, compression, type of gasoline and so on Lots of ways to get things done, some are cheaper than otherrs
Re: Lets hear your stupid fast 440 combo's [Re: 1967dartgt] #1029720
07/11/11 10:21 PM
07/11/11 10:21 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
why not smallblock?
Better be 8.30's or quicker.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Lets hear your stupid fast 440 combo's [Re: pittsburghracer] #1029721
07/11/11 11:02 PM
07/11/11 11:02 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
You name the road and its on...
Re: Lets hear your stupid fast 440 combo's [Re: 1967dartgt] #1029722
07/12/11 12:22 AM
07/12/11 12:22 AM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Not stupid fast by any stretch, but
446 stock forged crank
8.3:1 compression
230/236 @ .050 hydro stick
Mildly cleaned up Eddys
2" TTI`s
EFI
4000 PTC vert
3.54 gear
275 M/T radial
93 pump gas
race weight 4130
10.56 at 127 and change
Oh...I forgot, 12 PSI of boost
Rick
Re: Lets hear your stupid fast 440 combo's [Re: 1967dartgt] #1029723
07/12/11 02:28 AM
07/12/11 02:28 AM
PA.
"Little"John
"Little"John
PA.
Road???? What the heck are you talking about? What are we going to talk about next. NOS. I love when a guy builds a small block at about 10 times the cost of a big block and still has to add a power adder. My engines are built by ME in MY garage with off the shelf parts.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Lets hear your stupid fast 440 combo's [Re: Blown71X] #1029724
07/12/11 02:52 AM
07/12/11 02:52 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
My first 440 I had in the cuda:
.030" over TRW 11.5 to 1 on stock rods and crank (balanced)
ATI super damper
915 heads 78cc, 2.14 1.81 valves (mild port work)
1.5 crane roller rockers
.590 312 mopar cam
M1 single plane with 750 annular discharge holley
1" super sucker
4200 coan convertor
4.56 with 13 x 31 tire
Every bit of this stuff was used but the balancer, super sucker, gaskets, bearings, oil pump, and rings. Just cleaned up, honed, valve job, and new paint.
Car weighed 3330 with me in it. It went 10.64 in good air, 10.70-low 80's in the heat.
Re: Lets hear your stupid fast 440 combo's [Re: Blown71X] #1029725
07/12/11 06:05 AM
07/12/11 06:05 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
8.3:1 compression
2" TTI`s
EFI
4000 PTC vert
3.54 gear
275 M/T radial
93 pump gas
race weight 4130
Rick
Re: Lets hear your stupid fast 440 combo's [Re: pittsburghracer] #1029726
07/12/11 09:49 AM
07/12/11 09:49 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
yea i love when a guy spends 12.000$ on a set of predator heads,in a tube chassis car that weighs 2500lbs and does 8.30's u got an 8.30 car? bring it to etown and watch how many people will race u with small blocks...ps i dont believe u have an 8.30 car either..lol
Re: Lets hear your stupid fast 440 combo's [Re: fishy340] #1029727
07/12/11 10:18 AM
07/12/11 10:18 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
My point. You can make a 340 or any SB run it will just cost you a butt load of money. And forget about using one in a 3800 lb B-body. You can run 10's in a heavy b-body w/ a stock stroke 440 w/ good off the shelf heads, small roller or 600ish solid cam, 4000 stall and 4.56's.
Small blocks are fine and yeah they can be fast but at what cost? If you are building a bracket car and looking for 10.90's and don't have a deep wallet I'd think the best route to go is w/ a BB. The guy isn't talking about running 8's spinning his junk to 7500. He wants a weekend beater. Shoot I'd bet w/ a decent tune you could get a 440 into the 10's w/ an old school 509 and iron heads.
Re: Lets hear your stupid fast 440 combo's [Re: Mr.Yuck] #1029728
07/12/11 10:52 AM
07/12/11 10:52 AM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
I think to go fast on the cheap =big block
Moneys not an object= small block
End goals (anyones) can be met with ethier!
74 dart sport 440 www.Csucarbs.com
Re: Lets hear your stupid fast 440 combo's [Re: The Sphinx] #1029729
07/12/11 01:05 PM
07/12/11 01:05 PM
South Carolina, United States
carolinacuda Offline
440 .30 over
TRW 2355's zero deck
hughes solid cam 576/579 dur.252/256
eddy victor int with mighty demon 850
hooker headers 1 7/8 with 3" collect
3' exh
727 trans with crappy TCI 3500 stall
3.91 gears with 275's M/T radials
11.29 @120 mph
74cuda #3650lbs so in a 3000 car should run 10's easy.
Re: Lets hear your stupid fast 440 combo's [Re: carolinacuda] #1029730
07/12/11 02:52 PM
07/12/11 02:52 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Anyone can beat 8.67 1/4 mile time and 156 mph with a 440+060 build and 3.75 stroke ?
I helped a good friend build a 440+060 a couple of years ago.
All parts for the short block was bought from Scott Brown, besides a crane cam and an Eagle 3.75 crank he already had.
Stock RB block+060, with Eagle 3.75 crank
Pistons Ross 13:1 custom
Rods K1 steel, stock length
Cam Crane superstock grind IR-276/4714-2S-12
int. 0.707(1.5) exh. 0.670(1.5), dur. 276 at .050
Heads Indy 440-1 mildly ported with manley severe duty 2.20
Carb custom 1250 dominator on a 440-1 intake.
/Tom
Re: Lets hear your stupid fast 440 combo's [Re: pittsburghracer] #1029731
07/12/11 03:12 PM
07/12/11 03:12 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What you want to [Edited by Moparts - Family Friendly Site - Keep it clean] now? Didn't think your duster was that fast or we going to race the wrecked daytona? Oh and if its not on the street I am going to bring the small block dragster if you want to run race cars.
Re: Lets hear your stupid fast 440 combo's [Re: Mr.Yuck] #1029732
07/12/11 03:21 PM
07/12/11 03:21 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I used to have a 380 cu in 11.5 to 1 eddy headed stock block eagle rods that would go 10.70s on pump gas and 9.70s on c-12 and 200 shot.I didn't have alot of money in that setup. Got crank new closeout mopar 500, and got the eddys used 800. So I bought eagle rods and got the machine work done witch is pretty much the same big or small block.So I had about 4500 in whole motor to go 10.70s in a 3350 lb a body.
