trans recommendations #1028907
07/09/11 02:30 PM
07/09/11 02:30 PM
davenport iowa
P
paul69cuda Offline OP
P
davenport iowa
Here is the setup 68 dart street strip 440 with cast iron manifolds 62-65 reversed forward. Single bw s480 turbo with 4 inch down pipe fast fuel inject setup on a proflow
Xt manifold with a 90mil throttle body. The rear is d-60 with 373 gear with spool the motor will have edelbrocks out of the box comp will be between 8.5 9.0. The cam will be custom at a 113-114 lobe around 500-540 lift this setup should make 7-800 hp
At 10-12 psi. What are some of you guys doing for your tranny?
Re: trans recommendations [Re: paul69cuda] #1028908
07/09/11 04:34 PM
07/09/11 04:34 PM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
I am running a 833 4 speed. I am sure that third gear will not be able to hold that kind of horsepower.
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: trans recommendations [Re: paul69cuda] #1028909
07/09/11 06:48 PM
07/09/11 06:48 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Did you get those manifolds to fit? Mine hit the steering column.. I have schumaker mounts.. I will be running a 727, JW ulta comp converter.
Re: trans recommendations [Re: paul69cuda] #1028910
07/09/11 07:43 PM
07/09/11 07:43 PM
davenport iowa
P
P
davenport iowa
I notched the pass side shock tower and I have no problem with the steering at all.
Re: trans recommendations [Re: paul69cuda] #1028911
07/11/11 10:50 PM
07/11/11 10:50 PM
davenport iowa
P
P
davenport iowa
Redo of the question what did you do to your 727 for a street strip app. What modifications did you do....
Re: trans recommendations [Re: paul69cuda] #1028912
07/11/11 11:20 PM
07/11/11 11:20 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
727 with a Griener valve body, an super sprag, deep pan, blue clutches, 4.2 or 3.8 lever, and that would be good with the 3.73's
