Carb size for Dodge R5 P7 Engine? #1028150
07/08/11 01:52 AM
07/08/11 01:52 AM
Goat Rodeo
drago Offline OP
drago  Offline OP
Goat Rodeo
I know the nascar guys run an 830 holley. Would a 4500 dominator make more power?
thanks.
Re: Carb size for Dodge r5 p7? [Re: drago] #1028151
07/08/11 05:52 AM
07/08/11 05:52 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Yes
Alan Jones
Re: Carb size for Dodge r5 p7? [Re: LA360] #1028152
07/08/11 06:16 AM
07/08/11 06:16 AM
Goat Rodeo
drago Offline OP
drago  Offline OP
Goat Rodeo
Hi Alan,
thanks for the reply.
would either 1050 and 1150 carbs work?
thanks.
Re: Carb size for Dodge r5 p7? [Re: drago] #1028153
07/08/11 09:44 AM
07/08/11 09:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It would make a difference on how many CI and the RPM
you plan on turning
Re: Carb size for Dodge R5 P7 Engine? [Re: drago] #1028154
07/08/11 01:42 PM
07/08/11 01:42 PM
Shelbyville, TN USA
40ford Offline
mopar addict
40ford  Offline
mopar addict
Shelbyville, TN USA
The maximum size allowed by NASCAR is the 830 CFM Holley. The actual carb used by the top NASCAR teams may look like a 830, may have the correct dimensions for a 830 Holley-----but the are not a 830 Holley.
Yes, a P7 can use more than an 830, but how much more depends on RPM the engine is running. When we used our 358" P7 in an 2300 lb. oval track car, we used a highly modified 800 Holley---and it was good to about 9000. The cylinder heads are highly efficient, so it doesn't require as much carb as less efficient heads do.
Re: Carb size for Dodge R5 P7 Engine? [Re: 40ford] #1028155
07/09/11 04:11 AM
07/09/11 04:11 AM
Goat Rodeo
drago Offline OP
drago  Offline OP
Goat Rodeo
Hi,
were you rule limited to 800 cfm for that oval track car?
thanks.
Re: Carb size for Dodge R5 P7 Engine? [Re: drago] #1028156
07/10/11 01:01 PM
07/10/11 01:01 PM
Shelbyville, TN USA
40ford Offline
mopar addict
40ford  Offline
mopar addict
Shelbyville, TN USA
No, there are NO engine restrictions for late model dirt cars in the US. The ONLY restrictions are one carb and one spark plug per cylinder.
But, we raced primarily on short 1/4 and 1/3 mile tracks and sometimes we had RPMs down as low as 2500 under race conditions. So, engine response was important. And the 800CFM was seriously worked---flowed well over 900 CFM and the fuel curve was good for our type of race car.
Re: Carb size for Dodge r5 p7? [Re: drago] #1028157
07/11/11 09:54 AM
07/11/11 09:54 AM
LA360 Offline
LA360  Offline
Hi Alan,
thanks.
I will probably have RayJe Carbs in QLD do me a Dominator.
My engine won't be standard Nascar spec though.
If I had a Nascar spec engine I would try a 1050, not sure you would get the booster signal from an out of the box 1150. Depending on the camshaft, most make peak torque around 6500-6800 rpm and peak power at 8400+rpm. A 1000cfm 4150 Holley would be another option for you.
As has been already stated, the 830 Holley is used due to rules, they would run larger if they could.
40ford has alot of experience with these engines and currently runs one in a FED with mechanical fuel injection and zoomie headers. Great looking car to boot also!
Alan Jones
Re: Carb size for Dodge R5 P7 Engine? [Re: 40ford] #1028158
08/11/12 01:14 PM
08/11/12 01:14 PM
racerdude5 Offline
racerdude5  Offline
Where can you get mechanical fuel injection for the R5 P7, what part number is it? What is the approximate cost?
Re: Carb size for Dodge R5 P7 Engine? [Re: racerdude5] #1028159
08/11/12 09:07 PM
08/11/12 09:07 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
There are only a few intakes available to for the R5P7 motors. One is the original casting of which I think there are 3 but could be as many as 5. These are for specific tracks and some teams got their power in different ways from others.
There is a company that makes a cast intake that will take either a single 4 or a doul 4. They are a little pricey at $1600 each.
Then there is the all out lets go fast model which is the Sheet metal version and best bet there is a 2x4.
Now for the injection, you will need a specific intake built so your choices are limited. Built means either modify a current intake or have one built.
I know the engine builder I talked to said I would make the most power with a sheet metal intake. Not sure if I want to drop the $4000 on one or just pony up the $1600.
Yes 40Ford is prob. the most knowledgable on the board about these followed by Jesse(R5P7Duster) I am still a guppy in this shark tank...
Re: Carb size for Dodge R5 P7 Engine? [Re: mopartony] #1028160
08/11/12 09:22 PM
08/11/12 09:22 PM
LA360 Offline
LA360  Offline
Charles Sanborn (40ford) had Engler Machine make his stack injection, I think it was a one off. Contact them and find out
Alan Jones
Re: Carb size for Dodge R5 P7 Engine? [Re: LA360] #1028161
08/12/12 01:28 AM
08/12/12 01:28 AM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Engler had three castings for "I think" a Toyota or SP-2 sprint car head that had not had the manifold bolt holes drilled yet. The port spacing was almost identical to the P-7, so it was just a matter of drilling the P-7 bolt pattern and matching each base to the heads. The butterfly bodies are separate and could be bolted to different bases if needed. They (Sanborns)had three different sets of P-7's (Elliots, Davis's and one other, Arringtons, maybe)so that gave them flexibility if they decided to use a different head than the Elliots, since from what I understand, the intake ports are somewhat different on the three heads.
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: Carb size for Dodge R5 P7 Engine? [Re: racerdude5] #1028162
08/12/12 09:15 AM
08/12/12 09:15 AM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
I suggest you to contact Spud Miller on that question. Hes is top guy in mechanical injection parts and service. http://www.fuelinjectionenterprises.com/
Actually Iam also tire to go with mechanical injection with my R5P7 motor and we allready have thoughts with Spud on that
Georg
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: Carb size for Dodge R5 P7 Engine? [Re: Georg] #1028163
08/12/12 10:14 AM
08/12/12 10:14 AM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Georg,
Spud is great, but I think in this case, Engler is probably the only one that has the casting base that will work with the P-7 head, and I meant to say SB2 above, not SP....fat or dyslexic fingers on the keyboard....
BTW, I only answered for Charles last night because I knew it was late and he was already in bed.....
Ronny
John 14:6
Re: Carb size for Dodge R5 P7 Engine? [Re: 23T Hemmee] #1028164
08/12/12 02:03 PM
08/12/12 02:03 PM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
Georg,
Isnt there possebility to use R5P7 intake and mill plate between carb base and fuel injection plate? ( if to use shotgun or birdcather style )
Re: Carb size for Dodge R5 P7 Engine? [Re: Georg] #1028165
08/12/12 09:36 PM
08/12/12 09:36 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Oh yeah, most definitely would be the simplest way, especially with the P-7 being a rather specialized head. In Sanborn's case, the nostalgia association we run required straight port injection only, along with zoomies instead of collector headers for open wheel dragsters/altereds, although they have since relaxed the rules in regard to tunnel-ram/hat combo's. If Sanborn was starting from scratch building the car for the present rules today, he may very well have gone the manifold/hat route. And I apolgize for somewhat getting this thread off the OP's topic....
Ronny
John 14:6
Re: Carb size for Dodge R5 P7 Engine? [Re: 23T Hemmee] #1028166
08/13/12 02:05 AM
08/13/12 02:05 AM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
Soory I didnt knew about those rules in nostalgia class
Re: Carb size for Dodge R5 P7 Engine? [Re: Georg] #1028167
08/13/12 04:38 AM
08/13/12 04:38 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I'm running a quickfuel 4150 1050 cfm. The engine handles it great and performs much better than with the 900 I had on it originally. Granted both carbs worked well. I have no expeience running both in warm weather though, I ran both of them in -10° to 25° F
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Carb size for Dodge R5 P7 Engine? [Re: DemonDust] #1028168
08/14/12 01:26 PM
08/14/12 01:26 PM
Shelbyville, TN USA
40ford Offline
mopar addict
40ford  Offline
mopar addict
Shelbyville, TN USA
Tim Engler was very instrumental in supplying the stack injection for the P7. It was not just a matter of "adapting" the toyota or SB2 to the Dodge. The basic mold was used but a custom program was written for the cylinder heads. We supplied him with heads, valley cover and specific dimensions as well as air flow (cfm) to develop what is currently on the engine. He treated our project with as much attention as a team that would order multiple injection units (we only needed one). His help and advice after the fact has been second to none and always willing to listen and advise when asked. FWIW this engine is for sale (complete down to the custom converter) as we have moved to the 7.0 pro class with a 607 injected hemi. The 358" P7 achieved a best of 7.40 and more can be gotten but the hemi engine sort of just fell in our lap as a joint venture and we couldn't pass it up (besides it just looks plain sexy in a full bodied FED). If anyone has questions or wishes to inquire feel free to PM me.
