MSD Blaster is toast, Need Coil suggestions
#1023477
06/30/11 04:27 PM
06/30/11 04:27 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
'69 b body, 440 w/MP elec ign conversion.
This is my 2nd Blaster and I will not buy another one. Today, while doing some routine checking under the hood I noticed the top of my coil (which IS mounted vertically) had some oil film on it. I took a rag to wipe it off and unplugged the coil wire and the socket is filled with oil.
I do have the MSD ballast installed that folks here reccommended when I asked about using the blaster with the MP electronic conversion. The car is actually running really good, but I know that coil will leave me needing a tow.
I need to replace this coil and I do not want another oil filled blaster. What coil (make, part #, ebay, summit, whatever)would drop in its place for me?
Scott
1969 Super Bee, 383/4 speed
Re: MSD Blaster is toast, Need Coil suggestions
[Re: StukaJU87]
#1023486
06/30/11 04:47 PM
06/30/11 04:47 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
To quote the man himself.... Quote:
No, our CD coil will most likely burn up your Mopar Box. Don Gould at FBO sells a great coil for your Mopar Ignition. Tell him I sent you. Thanks for the kind words, guys.
Here's the whole thread....
https://board.moparts.org/ubbthreads/show...e=4#Post6700753
[Re: WILD BILL]
#1023487
06/30/11 04:54 PM
06/30/11 04:54 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
i don't understand how??? it's not like the voltage goes through the box........ Not saying either way but i don't see how??
[Re: mikemee1331]
#1023488
06/30/11 05:04 PM
06/30/11 05:04 PM
WILD BILL
BROOK PARK, OH
I don't get it either but I'm sure Rick knows his stuff and what he's talking about.
Come to think of it, there's a lot of things I don't get
[Re: WILD BILL]
#1023489
06/30/11 05:07 PM
06/30/11 05:07 PM
StukaJU87
Northern NJ
So......what epoxy filled coil do I need? Seems some of them have different voltage and ohms ratings.
Scott
[Re: StukaJU87]
#1023490
06/30/11 05:13 PM
06/30/11 05:13 PM
Posts: 15,487 Florida
scratchnfotraction
I use the pertronix points conversion with the 40,000 volt flame thrower coil. i have the BR by-passed to give it a full 12 volts to the coil been 15+ yrs with it in 4-5 engine combos the MP set up has left me walking too many times,I am a die hard pertronix conversion guy now. so..no help from me maybe you should swap to a points dist and a conversion set up I know I have never found the rpm limet yet..it allways throws a rod first
[Re: scratchnfotraction]
#1023491
06/30/11 07:37 PM
06/30/11 07:37 PM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
My Blaster is 10 years old.The one in my kids 62 300 was running the MP stuff.Now both are full MSDs and have been in the same amount of time.Never any problems.Rocky
Chrysler Firepower
[Re: StukaJU87]
#1023495
07/01/11 11:14 AM
07/01/11 11:14 AM
Posts: 1,472 Overland Park, KS.
Joshs68
Overland Park, KS.
FBO sells a coil that works well with factory ignition. It is even made in the USA...
2 questions on the FBO coil
1) Is there a link to buy it? I looked on their site, saw the coil, but could not find a link to purchase it.
2) Do I use the stock ballast resistor with the FBO coil or the same resistor I am using with the Blaster? (I think .8)
I would just call him. The hours and phone number are on the website. I use it with a chrome box and matching Mopar ballast resistor.
[Re: StukaJU87]
#1023496
07/01/11 02:58 PM
07/01/11 02:58 PM
Posts: 5,445 So Cal
Sinitro
So Cal
If running the Mopar electronic distributor, box (chrome or orange) and Blaster II coil the proper ballast resistor is 0.25 Ohms (#Mopar Performance 2444641).
Just my $0.02..
