Re: Driveshaft Phasing
[Re: buildanother]
#1022254
06/29/11 12:11 AM
06/29/11 12:11 AM
Posts: 387 Montreal PQ, Canada
74_360_Cuda
Montreal PQ, Canada
Bottom is correct
Thanks, I will have a new driveshaft made, I am going with 1350 plus my existing driveshaft was short and it is worst with the Hotchkis leaf springs. Does everyone just do it like it was on OEM?
[Re: BDW]
#1022258
06/30/11 08:57 AM
06/30/11 08:57 AM
Posts: 15,487 Florida
scratchnfotraction
it wil cause the u-joints to wear faster and cause harmonic problems out of phase the u-joints spin at diff speeds at the angles...kinda wobbles if you will. I have seen a lot of 4x4 drive shafts with this problem from the DIY home brewed shafts.
[Re: 74_360_Cuda]
#1022259
07/01/11 03:37 AM
07/01/11 03:37 AM
Posts: 203 Sante Fe Springs, CA
Hotchkis
Bottom is correct
74 360 Cuda – Get a driveshaft made by a shop that understands performance cars. Some don’t. You should never get a driveshaft made to stock specs. You should always measure it for your specific vehicle. The driveshaft shop will tell you exactly how THEY want you to measure it. Make sure your car is begin supported safely by jack stands under the rear end or you measure with your car on a drive-on rack. The car should be level too. The rear suspension should be compressed. New leaf springs can change the pinion angle by nature of repositioning the axle in relation to the body. Any ride height changes can alter pinion angle. Worn out U-joints can be aggravated by slight pinion angle changes from ride height change too. Have you checked your U-joints?
[Re: Hotchkis]
#1022260
07/02/11 04:12 AM
07/02/11 04:12 AM
74_360_Cuda
Montreal PQ, Canada
Bottom is correct
Thank you for the advices,I was aware of all that, just installed a set of your rear leaf springs and will be taking pignion angle measurement to see if I need to shim. I am also upgrading to 1350 joints with billet yokes...
