At what time do you think to add mains? #1021721
06/28/11 01:20 AM
06/28/11 01:20 AM
pro99 Offline OP
pro99  Offline OP
I was wondering at what point do you add new mains in a 440 motor? Looking to put a Source 512 kit in my 440, is it necessary to add new aftermarket main caps? I know its a good idea to have them but do you really need to. Thinking Compression will be around 12.36 to 12.00 depending on the heads I use.
1968 Dart Drag Car (I just bought it)
Re: At what time do you think to add mains? [Re: pro99] #1021722
06/28/11 08:26 AM
06/28/11 08:26 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
You might want to move this to the race section. I would say it depends on rpm. Keep it under 6000 and stock caps should be OK. Main studs with a line hone would be extra insurance. Approaching 7000 rpm and steel/aluminum main caps are suggested.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: At what time do you think to add mains? [Re: pro99] #1021723
06/28/11 11:46 AM
06/28/11 11:46 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Adding aluminum mains can be an expensive proposition as almost are bored for LB motors which have smaller mains (the 440Source ones are). This means they need to be align "bored" before align honing. Finding someone to do that is not as simple as finding a shop that does align honing. They also will likely need to be milled slightly to fit the registers so again you need a shop with a mill. If you're pushing this motor to its upper limits all the time or if money is no object then you should probably go for it, otherwise stick with the stock caps and studs.
Having just done a 440 based stroker I can tell you that in hindsight I should have done it with a 400-based block - you have bigger bores to start with so don't have to overbore as much to achieve the same c.i. and the aluminum caps can be installed with less hassle. Not to mention the weight savings! And 400 blocks have better support in the main webs.
Re: At what time do you think to add mains? [Re: Stanton] #1021724
06/28/11 06:30 PM
06/28/11 06:30 PM
No weight savings in most 400 blocks versus 440 blocks I have weighed a bunch of the(12 to 15), maybe 5 lbs(215 to 220 lbs) differences between both B and RB, no patterns on one type being lighter than the other I have built several Mopar strokers over the years, B,RB, Hemi, and SB, aftermarket main caps can't hurt in a motor that may see some detonation I agree on using a low deck to start with, I like them
Re: At what time do you think to add mains? [Re: Cab_Burge] #1021725
06/28/11 07:20 PM
06/28/11 07:20 PM
IN
ahy Offline
ahy  Offline
IN
A 12:1 512 sounds like a pretty stout engine. I think it would benefit from better main caps. Aluminum is supposed to be the best as it absorbs shock... although many (me included) run steel.
Re: At what time do you think to add mains? [Re: pro99] #1021726
06/28/11 10:06 PM
06/28/11 10:06 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
My opinion, if your making around 650-750 HP?
Below 650, you should be able to use the stock caps.
Above 750, the money would be better spent going towards a race block.
Re: At what time do you think to add mains? [Re: 451Mopar] #1021727
06/28/11 11:21 PM
06/28/11 11:21 PM
USA
BB Dart 69 Offline
BB Dart 69  Offline
USA
Chaz, get the aluminum caps and studs from Best Machine. He can line bore it to Mark
Re: At what time do you think to add mains? [Re: BB Dart 69] #1021728
06/28/11 11:30 PM
06/28/11 11:30 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
my , change the caps at 600-650 magazine horsepower. real world, i think 550 is max. i've seen the caps jumping around at less than 550. differing opinions here but i don't think the "b" engine bottom end is that strong.
Re: At what time do you think to add mains? [Re: lewtot184] #1021729
07/02/11 12:53 AM
07/02/11 12:53 AM
pro99 Offline OP
pro99  Offline OP
So what your saying is it would be best to do a 400 to 512 than a 440 to 512? If thats the case i need to find a 400 in a good year and sell my .030 over 440 then.
Re: At what time do you think to add mains? [Re: pro99] #1021730
07/02/11 03:19 AM
07/02/11 03:19 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Pic of my 4.15" stroked 400 (500 cid) with the BCR Aluminum Main caps and girdle:
Re: At what time do you think to add mains? [Re: 451Mopar] #1021731
07/02/11 08:27 PM
07/02/11 08:27 PM
pro99 Offline OP
pro99  Offline OP
Ok what is the best year 400 block should I look for and is there any to stay away from?
Re: At what time do you think to add mains? [Re: pro99] #1021732
07/04/11 07:01 PM
07/04/11 07:01 PM
pro99 Offline OP
pro99  Offline OP
Anyone???
Re: At what time do you think to add mains? [Re: pro99] #1021733
07/04/11 07:09 PM
07/04/11 07:09 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
The most desirable block to start with would be the "71 230 casting WITH the thicker main webbing (not all 230 castings have this). However, any 400 that sonic checks good is a decent starting point. A partial fill, studded mains with aluminum caps, and a girdle should make for a pretty stout platform.
BTW: if your asking questions like this now, invest in Andy F's book, How to build Max Performance Mopar big blocks. He goes over all this and more, and he's a moparts member here, so its supporting a friend
