At what time do you think to add mains?
#1021721
06/28/11 01:20 AM
06/28/11 01:20 AM
Posts: 51 Michigan
pro99
I was wondering at what point do you add new mains in a 440 motor? Looking to put a Source 512 kit in my 440, is it necessary to add new aftermarket main caps? I know its a good idea to have them but do you really need to. Thinking Compression will be around 12.36 to 12.00 depending on the heads I use.
1968 Dart Drag Car (I just bought it)
Re: At what time do you think to add mains?
[Re: pro99]
#1021722
06/28/11 08:26 AM
06/28/11 08:26 AM
Posts: 1,443 Maryland
Dads426
Maryland
You might want to move this to the race section. I would say it depends on rpm. Keep it under 6000 and stock caps should be OK. Main studs with a line hone would be extra insurance. Approaching 7000 rpm and steel/aluminum main caps are suggested.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Stanton]
#1021724
06/28/11 06:30 PM
06/28/11 06:30 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
Adding aluminum mains can be an expensive proposition as almost are bored for LB motors which have smaller mains (the 440Source ones are). This means they need to be align "bored" before align honing. Finding someone to do that is not as simple as finding a shop that does align honing. They also will likely need to be milled slightly to fit the registers so again you need a shop with a mill. If you're pushing this motor to its upper limits all the time or if money is no object then you should probably go for it, otherwise stick with the stock caps and studs. Not to mention the weight savings! And 400 blocks have better support in the main webs.
No weight savings in most 400 blocks versus 440 blocks I have weighed a bunch of the(12 to 15), maybe 5 lbs(215 to 220 lbs) differences between both B and RB, no patterns on one type being lighter than the other I have built several Mopar strokers over the years, B,RB, Hemi, and SB, aftermarket main caps can't hurt in a motor that may see some detonation I agree on using a low deck to start with, I like them
[Re: pro99]
#1021733
07/04/11 07:09 PM
07/04/11 07:09 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
The most desirable block to start with would be the "71 230 casting WITH the thicker main webbing (not all 230 castings have this). However, any 400 that sonic checks good is a decent starting point. A partial fill, studded mains with aluminum caps, and a girdle should make for a pretty stout platform. BTW: if your asking questions like this now, invest in Andy F's book, How to build Max Performance Mopar big blocks. He goes over all this and more, and he's a moparts member here, so its supporting a friend
