Page 2 of 3 1 2 3
Re: adding a sunroof 71-4 b body [Re: Dodge] #1020259
06/28/11 09:59 AM
06/28/11 09:59 AM
ME
79machocharger Offline
ME
I would never do or own a Dukes Charger, but the one above is bad a$$! I have to ask, did you have it installed? Thanks Terry
Yes I installed it. It came out of a factory sunroof abody. The car was a blast, it had all kinds of goodies on it including electronic cutouts on the exhaust.
http://www.youtube.com/watch?v=tjCdfyS0oQs
Re: adding a sunroof 71-4 b body [Re: 79machocharger] #1020260
07/02/11 01:30 PM
07/02/11 01:30 PM
Tulsa, Oklahoma
Charger_440 Offline OP
Tulsa, Oklahoma
Man, what great information you guys! Thanks to all of u. The black general lee is cooool man! Mike, thank you for the info about the Volvo top. I was looking into a glass top, but that might be cool. I suppose it would have enough clearance to use with vinyl top material on the door part of it? And does it matter what year for the 80s Volvo?
In a conversation with a Wyoming State Patrolman... "A 318 ??!!! But I clocked you at 142 mph!!!"
Re: adding a sunroof 71-4 b body [Re: Charger_440] #1020261
07/02/11 04:53 PM
07/02/11 04:53 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Brandon,....electric glasstop/sliding roofs can be found in the mid 80's Diplomat/Lebaron line, but the front/leading edge of the glass will be curved, following the windshield/roof line, if that's ok?,....or if you want a modern electric rectangular sliding glass roof, mid 90 and up Volvos are equipped this way
Re: adding a sunroof 71-4 b body [Re: DAYCLONA] #1020262
07/03/11 02:45 PM
07/03/11 02:45 PM
Tulsa, Oklahoma
Tulsa, Oklahoma
would i be able to install the vinyl top material over the door if i used the steel volve one? without it rubbing or pulling up at the edges?
Re: adding a sunroof 71-4 b body [Re: Charger_440] #1020263
07/03/11 03:45 PM
07/03/11 03:45 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Even on the factory (ASC) sunroofs wrapped in vinyl, the fit around the perimter/panel is tight, you'd need a healty 1/4" gap around between the panel and roofskin to wrap the vinyl around both, that's why I prefere to use the existing hardtop roof and covert it into a sunroof opening, rather than graft the donor's sunroof skin in,...I can control the opening, either increasing/decreasing the opening, or correcting flaws, the sliding panel only relys on the hole in the roof to fill the opening when closed, so make the opening to your clearance specs
One of the advantages of using a newer cassette, is the cassette bolts into the car, so you have some wiggle room to locate the sliding door in the opening,...the 'FACTORY' ASC cassettes relied on not just bolting/welding in along the rear of the cassette, but the front and sides of the cassette needed to be spot welded to the sunroof opening flanges that roll into the sunroof opening, then you were left with playing with the sliding panel to get it not just 'SQUARED' in the opening, but able to drop down and travel back without hanging up, or skidding on the underside ruining the paint or vinyl mat'l, often tedious and fustrating,...On another note, that I failed to mention,...what I like to do is add a "band" of steel directly under the rear opening, under the roof skin, that goes from one side of the drip rail to the other, and across the entire width of the roof to support the roof skin, as it becomes a weakened/flexible area once the opening is installed,...generally a 1/8" thick by 6" wide band, X the width of the car, you don't see it after the headliner is in, nor when the panel is open, just a structual support of the roofskin, much like the factory ribs already in place, basically replacing the one that has to be removed to install the cassette, the factory did nothing to replace the lost crossmenber, but I find that the area needs some beefing IMHO
Mike
Re: adding a sunroof 71-4 b body [Re: DAYCLONA] #1020264
06/30/13 03:26 PM
06/30/13 03:26 PM
Alberta, Canada
K
krisiesmopes Offline
K
Alberta, Canada
I know, 2 year old thread, but interesting. Does anyone know the correct measurements, or how to ID a factory E/B body unit? The reason I ask is I had a fellow here yesterday buying parts for his 71 Charger, and when we were looking through the sheemetal he spied my sunroof... I got it in a large parts purchase from an E body guy. He said it was from a Challenger he parted years ago (like 79-80). I an take a boatload of pix no problem. This guy wanted to buy it, and asked me to think up a price... I have no idea.
Re: adding a sunroof 71-4 b body [Re: krisiesmopes] #1020265
06/30/13 04:30 PM
06/30/13 04:30 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IIRC...the 70-2 E/71-2 B unit will be approx 42"X20" give or take, electric only....depending on condition and completeness they can fetch from $700-$1200 on average
Mike
Re: adding a sunroof 71-4 b body [Re: DAYCLONA] #1020266
06/30/13 06:03 PM
06/30/13 06:03 PM
Alberta, Canada
K
K
Alberta, Canada
I went and looked, it is 40 - 3/4 X 20 or so. Hand crank. I crank it, an it drops and slides back smooth, then goes back up no problem...possibly 73 B body then? I am uploading a bunch of pictures right now, but have slow internet so...
Re: adding a sunroof 71-4 b body [Re: krisiesmopes] #1020267
06/30/13 06:10 PM
06/30/13 06:10 PM
Alberta, Canada
K
K
Alberta, Canada
Re: adding a sunroof 71-4 b body [Re: krisiesmopes] #1020268
06/30/13 06:19 PM
06/30/13 06:19 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
What you have is indeed the 73 and up B body handcrank version, the A body handcrank version is 36"X20" and slightly curved in the front opening edge also
A 73 and up B body handcrank version is at best, worth a few hundred
Re: adding a sunroof 71-4 b body [Re: DAYCLONA] #1020269
07/01/13 12:46 AM
07/01/13 12:46 AM
Alberta, Canada
K
K
Alberta, Canada
Thanks for the info, I appreciate it.
Re: adding a sunroof 71-4 b body [Re: krisiesmopes] #1020270
03/03/14 03:56 PM
03/03/14 03:56 PM
Tulsa, Oklahoma
Tulsa, Oklahoma
adding bk to fav posts.
Re: adding a sunroof 71-4 b body [Re: Charger_440] #1020271
03/03/14 06:30 PM
03/03/14 06:30 PM
Western PA
O
OldMoparMan Offline
OldMoparMan  Offline
O
Western PA
Just a note if your picking up a used roof.
I have a factory sun roof in the dart sport and the aluminum driving block was totally worn out I had to help the roof open and close.
I just had a buddy on mine machine one out of brass and make it just a little tighter in the cable slots and it works great.
Living with ALS help support the search for a cure
Thanks http://web.alsa.org/site/TR/Walks/WesternPennsylvania?team_id=347781&pg=team&fr_id=12069
Re: adding a sunroof 71-4 b body [Re: OldMoparMan] #1020272
03/03/14 07:17 PM
03/03/14 07:17 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed,common problem with all the sunroofs, hand crank or electric they all use an aluminum block for the cable slides and drive mechanism to open/close the panel, I usually machine a replacement in steel, then case harden it for wear...
Mike
Re: adding a sunroof 71-4 b body [Re: DAYCLONA] #1020273
03/05/14 10:00 PM
03/05/14 10:00 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
Neat post... 18 years ago..I was building a nice driver for my wife , a 72 Charger. As I was working on it she had mentioned she would love to have a moon roof.....so I just so happened to know of one on a 1975 Cordoba ..I bought the whole roof. I then did a lot of measuring and I got it to fit nice and I will probably put one in my other Charger.
Re: adding a sunroof 71-4 b body [Re: GLR] #1020274
03/06/14 02:02 AM
03/06/14 02:02 AM
Tulsa, Oklahoma
Tulsa, Oklahoma
glr, thanks for the pic. nice looking job!
Re: adding a sunroof 71-4 b body [Re: Charger_440] #1020275
03/06/14 02:41 AM
03/06/14 02:41 AM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
You are welcome.. I have some more. I will post another.
Re: adding a sunroof 71-4 b body [Re: GLR] #1020276
03/06/14 05:21 PM
03/06/14 05:21 PM
S.E.Ohio
Magnumguy Online content
Magnumguy  Online Content
S.E.Ohio
Awesome thread!! I plan on doing this to my original Magnum I bought new. I have a t-top roof and moonroof (from a 77 Doba). I'd rather have the power setup from a 78-79 Magnum (if anyone knows of one)
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: adding a sunroof 71-4 b body [Re: GLR] #1020277
03/06/14 08:38 PM
03/06/14 08:38 PM
Tulsa, Oklahoma
Tulsa, Oklahoma
GLR that looks very clean all the way around. I see that you have the solid slider with vinyl on it...did you fab your own opening like Dayclona was saying , or did you graft in a roof section from the donor car?
Re: adding a sunroof 71-4 b body [Re: Charger_440] #1020278
03/06/14 11:57 PM
03/06/14 11:57 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
I grafted in the section in from the 75 Cordoba's original roof around the opening. I have done a lot of customizing so to me it wasn't hard to do but I have been doing restorations and custom work for years. It takes a lot of time to graft in a moon roof correctly. Then once the moon roof opening section is welded in and the cassette box is installed into position, drains have to be run and then I had to figure out what to put up so that I could attach head liner material too and you wouldn't believe what I used... I used a Bath tub/shower surround...
Page 2 of 3 1 2 3
