Spider gears interchange for suregrip clutch type #1020004
06/25/11 01:40 AM
06/25/11 01:40 AM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
I have a suregrip clutch type where the case bolts loosened up and let a spider gear go through the case and is trapped in the window area of the case. The case, clutches, and mechanics are still good and look undamaged. I was wondering if maybe non suregrip spider gears will interchange? If not what will?
I know they make new ones but I am having some issues with hours and spending $200.00 when its not important at this time is out of the question.
thank you moparts
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Spider gears interchange for suregrip clutch type [Re: TX9H6E4CUDA] #1020005
06/25/11 09:06 PM
06/25/11 09:06 PM
minnarusta
minnarusta
Anyone
Re: Spider gears interchange for suregrip clutch type [Re: TX9H6E4CUDA] #1020006
06/26/11 01:08 AM
06/26/11 01:08 AM
OK
70SWGR Offline
70SWGR  Offline
OK
You might send Cass(DoctorDiff) a PM?
Re: Spider gears interchange for suregrip clutch type [Re: TX9H6E4CUDA] #1020007
06/26/11 02:47 AM
06/26/11 02:47 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Unfortunately, spider gears from an open differential won't interchange.
BTW, a set of repro spider gears cost $100.
Re: Spider gears interchange for suregrip clutch type [Re: TX9H6E4CUDA] #1020008
06/26/11 10:04 AM
06/26/11 10:04 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Was this clutch type installed in a working chuck ? There is no way on gods green earth for what you say happened without damaging more than a spider gear.
Re: Spider gears interchange for suregrip clutch type [Re: JohnRR] #1020009
06/26/11 10:14 AM
06/26/11 10:14 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Just what I was thinking
