Harland Sharp rockers and pushrods question #1019704
06/24/11 03:47 PM
06/24/11 03:47 PM
Kerpen, Germany
426keith Offline OP
426keith  Offline OP
Kerpen, Germany
After rocker breakage Im changing my Indy rockers for a set of Harland sharps. Heads are Indys 440-1. Do the HS rockers use the same length pushrods as the indyrockers or do I need a new set?
Thanks for any help,
Chris
Re: Harland Sharp rockers and pushrods question [Re: 426keith] #1019705
06/24/11 04:29 PM
06/24/11 04:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I take nothing for granted and measure EVERYTHING just to be sure.
Re: Harland Sharp rockers and pushrods question [Re: Thumperdart] #1019706
06/24/11 04:41 PM
06/24/11 04:41 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
Give them a
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Harland Sharp rockers and pushrods question [Re: 426keith] #1019707
06/24/11 05:23 PM
06/24/11 05:23 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
i used the same push rods when i switched over but i had to add .015 shims under the shafts.that was more due to the adjusters being different.
Re: Harland Sharp rockers and pushrods question [Re: 426keith] #1019708
06/24/11 05:55 PM
06/24/11 05:55 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Chris
Sorry i have anything to add.But I'm in the same boat looking to replace the Indys with Harlands so I'll be keeping a eye on on this post.
Re: Harland Sharp rockers and pushrods question [Re: Thumperdart] #1019709
06/24/11 06:24 PM
06/24/11 06:24 PM
Ohio
3404 Offline
3404  Offline
Ohio
X2
Put the new rockers on and check them with the pushrods you have.
Re: Harland Sharp rockers and pushrods question [Re: 3404] #1019710
06/24/11 09:30 PM
06/24/11 09:30 PM
ky
68roadrunner Offline
ky
the hs will require a shorter push rod than the indy/dove
Re: Harland Sharp rockers and pushrods question [Re: 68roadrunner] #1019711
06/25/11 12:08 AM
06/25/11 12:08 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
know one will know the right answer except you. Head and block decking makes a diff on push rod length. You can get by with 2-3 threads showing out the adjuster, if more, you might just get by with a set of $40 lash caps...
Just get your new rockers and see.
Re: Harland Sharp rockers and pushrods question [Re: Bob_Coomer] #1019712
06/26/11 03:38 PM
06/26/11 03:38 PM
Mo.
racerx Offline
racerx  Offline
Mo.
? when u say 2-3 threads showing r we talking about the threads on top of the rockers or the bottom?
Re: Harland Sharp rockers and pushrods question [Re: racerx] #1019713
06/26/11 04:41 PM
06/26/11 04:41 PM
Missouri
Challenger Offline
Challenger  Offline
Missouri
Talking about the bottom!
Re: Harland Sharp rockers and pushrods question [Re: Challenger] #1019714
06/26/11 05:17 PM
06/26/11 05:17 PM
Mo.
racerx Offline
racerx  Offline
Mo.
After setting lash?...Thax.
Re: Harland Sharp rockers and pushrods question [Re: racerx] #1019715
06/26/11 08:11 PM
06/26/11 08:11 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
I was @ NMCA in Joliet today. I talked to HS rep. he said $1000 for a set for big Mopar with Indy heads. Not the offset intakes either!
Did they go up or is the show price WAY high. Or is the show rep. HIGH?
My Don
Re: Harland Sharp rockers and pushrods question [Re: cudadon] #1019716
06/26/11 08:56 PM
06/26/11 08:56 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Harland Sharps website doesn't show the standard rockers being that high. You can see their retail prices here - http://www.harlandsharp.com/products.htm
Re: Harland Sharp rockers and pushrods question [Re: 68roadrunner] #1019717
06/26/11 09:12 PM
06/26/11 09:12 PM
P
PorkyPig Offline
PorkyPig  Offline
P
I think this guys right. From what I recall messing with HS, Dove and Crane rockers years ago, none of them would use the same length pushrod when I set them up to see which fit my heads best.
Re: Harland Sharp rockers and pushrods question [Re: PorkyPig] #1019718
06/27/11 02:19 AM
06/27/11 02:19 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
I just went thru this exact same swap last year. The HS will require a different length push rod.
I will recommend Smith Brothers push rods while I am replying. Awesome tech help and quick order filling. They act like they want your business. Nice to have good service once in a while.
Hope this helps, Beep
Re: Harland Sharp rockers and pushrods question [Re: Bigbeep] #1019719
06/27/11 08:30 AM
06/27/11 08:30 AM
ky
ky
x2 smith bros. even wanted me to send in my old smith bros. pushrods to have them shortend. did not have time, so they next day aired me some. made the next weekend race and runnered up in a 5k race.
Re: Harland Sharp rockers and pushrods question [Re: 426keith] #1019720
06/27/11 11:06 AM
06/27/11 11:06 AM
fresno ca
mikeysmopars Offline
fresno ca
Are they Indy pushrods
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Harland Sharp rockers and pushrods question [Re: mikeysmopars] #1019721
06/27/11 12:48 PM
06/27/11 12:48 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
re the above
If they are they're junk anyhow.
Re: Harland Sharp rockers and pushrods question [Re: Stanton] #1019722
06/28/11 01:25 AM
06/28/11 01:25 AM
On the run…
On the run…
re the above
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Harland Sharp rockers and pushrods question [Re: BloFish] #1019723
06/29/11 02:05 AM
06/29/11 02:05 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
I may have spoke too soon as I forgot why I was actually changing rockers at the time. I had the pushrods indy sells with the -1 kit and comp roller lifters. Well a few of the pushrods were soft and the ball end of them was grinding off in the lifter cup. After looking at the roller lifter a little closer, I noticed the cup looked like it was too small for a 3/8" ball end. It was. I called comp to verify. So while I was replacing the pushrods I installed the HS rockers that I had already bought to replace the indy /dove rockers next time I freshened the motor.
So I probably spoke out of turn as the pushrod length more than likely changed because of the difference in diameter of the ball end of the pushrod. Sorry I don't remember what the particulars are on the old pushrods compared to the new ones. Sorry for any confusion, Beep
Thanks 440Jim for jarring my memory of why I was swapping the rockers in the first place. Beep
