Re: Harland Sharp rockers and pushrods question
[Re: 426keith]
#1019708
06/24/11 05:55 PM
06/24/11 05:55 PM
Posts: 4,075 Mo.
racerx
Mo.
After rocker breakage Im changing my Indy rockers for a set of Harland sharps. Heads are Indys 440-1. Do the HS rockers use the same length pushrods as the indyrockers or do I need a new set?
Thanks for any help, Chris
Sorry i have anything to add.But I'm in the same boat looking to replace the Indys with Harlands so I'll be keeping a eye on on this post.
[Re: Thumperdart]
#1019709
06/24/11 06:24 PM
06/24/11 06:24 PM
Posts: 1,369 Ohio
3404
Ohio
I take nothing for granted and measure EVERYTHING just to be sure.
X2 Put the new rockers on and check them with the pushrods you have.
[Re: 68roadrunner]
#1019711
06/25/11 12:08 AM
06/25/11 12:08 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
know one will know the right answer except you. Head and block decking makes a diff on push rod length. You can get by with 2-3 threads showing out the adjuster, if more, you might just get by with a set of $40 lash caps... Just get your new rockers and see.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#1019712
06/26/11 03:38 PM
06/26/11 03:38 PM
Posts: 4,075 Mo.
racerx
Mo.
? when u say 2-3 threads showing r we talking about the threads on top of the rockers or the bottom?
[Re: racerx]
#1019713
06/26/11 04:41 PM
06/26/11 04:41 PM
Posts: 221 Missouri
Challenger
Missouri
Talking about the bottom!
[Re: Challenger]
#1019714
06/26/11 05:17 PM
06/26/11 05:17 PM
Posts: 4,075 Mo.
racerx
Mo.
After setting lash?...Thax.
[Re: racerx]
#1019715
06/26/11 08:11 PM
06/26/11 08:11 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
I was @ NMCA in Joliet today. I talked to HS rep. he said $1000 for a set for big Mopar with Indy heads. Not the offset intakes either! Did they go up or is the show price WAY high. Or is the show rep. HIGH? My Don
[Re: 68roadrunner]
#1019717
06/26/11 09:12 PM
06/26/11 09:12 PM
Posts: 610 long time lurker, short time p...
PorkyPig
the hs will require a shorter push rod than the indy/dove
I think this guys right. From what I recall messing with HS, Dove and Crane rockers years ago, none of them would use the same length pushrod when I set them up to see which fit my heads best.
[Re: Bigbeep]
#1019719
06/27/11 08:30 AM
06/27/11 08:30 AM
Posts: 877 ky
68roadrunner
ky
I just went thru this exact same swap last year. The HS will require a different length push rod. I will recommend Smith Brothers push rods while I am replying. Awesome tech help and quick order filling. They act like they want your business. Nice to have good service once in a while.
Hope this helps, Beep
x2 smith bros. even wanted me to send in my old smith bros. pushrods to have them shortend. did not have time, so they next day aired me some. made the next weekend race and runnered up in a 5k race.
