Clutch helper spring removal #1019373
06/23/11 08:21 PM
06/23/11 08:21 PM
Oklahoma City
Spraygoon Offline OP
Oklahoma City
Other than cutting the spring, anyone have a good suggestion for removing the clutch helper spring on a 70 Cuda?? Thanks in advance.
Paul
Paul Reber
Re: Clutch helper spring removal [Re: Spraygoon] #1019374
06/23/11 08:40 PM
06/23/11 08:40 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Cram as many washers between the coils as you can as a helper depresses the pedal for you.
When you've done that then grab a BIG screwdriver or a suitable pry bar and simply wedge the near end off the pin. Its scarier than it sounds, while the spring is huge, it has very little travel.
Wear safety glasses though.
