Re: Apologies - what will this thing run?
[Re: boscosis]
#1018067
06/21/11 10:41 PM
06/21/11 10:41 PM
Posts: 2,141 junction city oregon
viperblue72
I will guess [Email]11.5@116[/Email]but I don't know how much a Satellite weighs.
[Re: boscosis]
#1018070
06/21/11 11:10 PM
06/21/11 11:10 PM
Triple Threat
Renton Washington
low 12's I bet. Maybe high 11's if it leaves well. Fairly heavy car with not much gear or converter. That engine in a dedicated drag car would go 10's.
[Re: Crizila]
#1018072
06/22/11 12:25 AM
06/22/11 12:25 AM
Posts: 93 CA
mojavered
CA
11.93 ![](/ubbthreads/images/graemlins/beer.gif) What do we win if we get the closest?
71 Challenger RT 440 / 727 / 8.75
[Re: ProStock1320]
#1018074
06/22/11 01:22 AM
06/22/11 01:22 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: viperblue72]
#1018076
06/22/11 02:00 AM
06/22/11 02:00 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Little less gear and converter than my car. little less cam, but it's a roller vs. my flat tappet solid. Stealth heads vs. eddys. Same intake & headers. smaller carb... I'll guess 12.60 first time out.
My 67 weighs 3620 without me. Steel wheels on my car.
[Re: StealthWedge67]
#1018077
06/22/11 03:30 AM
06/22/11 03:30 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Its not much off from my old eng. I had the .557 solid cam and 906 heads I worked. But the gear will hold the et down a little as I ran 4.30's with 30" tall tires. Mine went 11.49 best so I will guess 11.90's first time out. Good luck , Ron
[Re: 383man]
#1018078
06/22/11 07:55 AM
06/22/11 07:55 AM
Posts: 10,022 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I'm betting low twelves with a mph north of 112, mid 11 sec capability with gears, better converter and big slicks. Very good choices on the motor, It should stand tall among similar builds.
[Re: boscosis]
#1018080
06/22/11 11:11 AM
06/22/11 11:11 AM
Posts: 1,178 Indy
FlyFish
Indy
First time out I know will be interesting.
'66 Satellite, 3.55 gear, 3200 converter (estimate). 451, stock RPM heads, 10:1, solid roller 246/254 with 543/561 lift, performer RPM intake, 750 DP, 1 7/8 headers, 3" bullet mufflers.
This is my drive it every few months car; but I will take it to the track to see what it runs. I'll use either drag radials or slicks.
Let me preface this with I DON’T KNOW BIG BLOCKS…but I would think you would hit high 11’s.
FWIW, my small block stroker has almost the exact same compression, cam, carb, head (Edelbrock), intake. The only big difference is I’m short about 40 cubes, I run a 4.10 gear and weigh probably about 400lbs less (3250#)…it runs high 10’s.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: ProStock1320]
#1018083
06/22/11 04:11 PM
06/22/11 04:11 PM
Posts: 2,177 ill
dennismopar73
ill
12.65 DAMHIK. Anyone in the market for a 66 Satellite?
yes me!! but need money first ![](/ubbthreads/images/graemlins/bawling.gif)
