Apologies - what will this thing run? #1018065
06/21/11 10:39 PM
06/21/11 10:39 PM
boscosis Offline OP
super street
boscosis  Offline OP
super street
First time out I know will be interesting.
'66 Satellite, 3.55 gear, 3200 converter (estimate).
451, stock RPM heads, 10:1, solid roller 246/254 with 543/561 lift, performer RPM intake, 750 DP, 1 7/8 headers, 3" bullet mufflers.
This is my drive it every few months car; but I will take it to the track to see what it runs. I'll use either drag radials or slicks.
Re: Apologies - what will this thing run? [Re: boscosis] #1018066
06/21/11 10:41 PM
06/21/11 10:41 PM
southern California
1970sixpak Offline
1970sixpak  Offline
southern California
12.40
Re: Apologies - what will this thing run? [Re: boscosis] #1018067
06/21/11 10:41 PM
06/21/11 10:41 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I will guess [Email]11.5@116[/Email]but I don't know how much a Satellite weighs.
Re: Apologies - what will this thing run? [Re: viperblue72] #1018068
06/21/11 10:48 PM
06/21/11 10:48 PM
boscosis Offline OP
super street
boscosis  Offline OP
super street
I'm not sure yet either but my guess is about 3600 with me in it. It was already pretty useless on street tires with a 230/236 hydraulic flat tappet cam but that doesn't tell me much about how it will run at the track.
Re: Apologies - what will this thing run? [Re: boscosis] #1018069
06/21/11 11:10 PM
06/21/11 11:10 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
Low to mid 13s. I think the carb will hold you back.
Old, tired, and sometimes broke down. Me, not my car...
Re: Apologies - what will this thing run? [Re: boscosis] #1018070
06/21/11 11:10 PM
06/21/11 11:10 PM
Renton Washington
Triple Threat Offline
Renton Washington
low 12's I bet. Maybe high 11's if it leaves well. Fairly heavy car with not much gear or converter. That engine in a dedicated drag car would go 10's.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Apologies - what will this thing run? [Re: boscosis] #1018071
06/22/11 12:00 AM
06/22/11 12:00 AM
Az
Crizila Offline
Crizila  Offline
Az
12.90 - with a tail wind.
Fastest 300
Re: Apologies - what will this thing run? [Re: Crizila] #1018072
06/22/11 12:25 AM
06/22/11 12:25 AM
CA
mojavered Offline
mojavered  Offline
CA
11.93
What do we win if we get the closest?
71 Challenger RT
440 / 727 / 8.75
Re: Apologies - what will this thing run? [Re: Crizila] #1018073
06/22/11 12:25 AM
06/22/11 12:25 AM
Eastern WA
P
ProStock1320 Offline
P
Eastern WA
12.65 DAMHIK. Anyone in the market for a 66 Satellite?
Re: Apologies - what will this thing run? [Re: ProStock1320] #1018074
06/22/11 01:22 AM
06/22/11 01:22 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
11.71 @ 117
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Apologies - what will this thing run? [Re: Shoozy] #1018075
06/22/11 01:52 AM
06/22/11 01:52 AM
V
viperblue72 Offline
viperblue72  Offline
V
Wouldn't hold it back THAT MUCH!
Re: Apologies - what will this thing run? [Re: viperblue72] #1018076
06/22/11 02:00 AM
06/22/11 02:00 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Little less gear and converter than my car. little less cam, but it's a roller vs. my flat tappet solid. Stealth heads vs. eddys. Same intake & headers. smaller carb... I'll guess 12.60 first time out.
My 67 weighs 3620 without me. Steel wheels on my car.
Re: Apologies - what will this thing run? [Re: StealthWedge67] #1018077
06/22/11 03:30 AM
06/22/11 03:30 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Its not much off from my old eng. I had the .557 solid cam and 906 heads I worked. But the gear will hold the et down a little as I ran 4.30's with 30" tall tires. Mine went 11.49 best so I will guess 11.90's first time out. Good luck , Ron
Re: Apologies - what will this thing run? [Re: 383man] #1018078
06/22/11 07:55 AM
06/22/11 07:55 AM
gregsdart Offline
gregsdart  Offline
I'm betting low twelves with a mph north of 112, mid 11 sec capability with gears, better converter and big slicks. Very good choices on the motor, It should stand tall among similar builds.
Re: Apologies - what will this thing run? [Re: boscosis] #1018079
06/22/11 10:46 AM
06/22/11 10:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
On decent tires maybe a 12.20
Re: Apologies - what will this thing run? [Re: boscosis] #1018080
06/22/11 11:11 AM
06/22/11 11:11 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Let me preface this with I DON’T KNOW BIG BLOCKS…but I would think you would hit high 11’s.
FWIW, my small block stroker has almost the exact same compression, cam, carb, head (Edelbrock), intake. The only big difference is I’m short about 40 cubes, I run a 4.10 gear and weigh probably about 400lbs less (3250#)…it runs high 10’s.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Apologies - what will this thing run? [Re: FlyFish] #1018081
06/22/11 11:53 AM
06/22/11 11:53 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
12.19.
Re: Apologies - what will this thing run? [Re: viperblue72] #1018082
06/22/11 03:54 PM
06/22/11 03:54 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Yeah that is a odd statement Seeing i ran 10.9s @ 122 consistently with one on my 451, with a "best" of 10.91
I'll say 12.0s or 11.9s @ 113-114
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Apologies - what will this thing run? [Re: ProStock1320] #1018083
06/22/11 04:11 PM
06/22/11 04:11 PM
ill
dennismopar73 Offline
ill
yes me!! but need money first
Re: Apologies - what will this thing run? [Re: joedust451] #1018084
06/22/11 11:35 PM
06/22/11 11:35 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
With good tires... 12.0s - 12.20s.
