440 source water pump is making noises after maybe 700 miles?
I have the right side housing and want to install the Mopar performance water pump in the 440 source housing will it fit/work with out any issues?
Not real happy with the 440 source housing , the thermostat housing bolt holes were spaced wrong, wasen't finish machined for the thermostat, and the mounting boss didn't fit with the stock brackets for the power steering, but other than that it worked OK, no issues with cooling. Lucky for me I have a mill, lathe etc... in the garage and made it all work. That was easier than sending it back and dealing with the border issues, etc....
