Will a Mopar water pump fit a 440 source housing? #1017892
06/21/11 07:15 PM
06/21/11 07:15 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
440 source water pump is making noises after maybe 700 miles?
I have the right side housing and want to install the Mopar performance water pump in the 440 source housing will it fit/work with out any issues?
Not real happy with the 440 source housing , the thermostat housing bolt holes were spaced wrong, wasen't finish machined for the thermostat, and the mounting boss didn't fit with the stock brackets for the power steering, but other than that it worked OK, no issues with cooling. Lucky for me I have a mill, lathe etc... in the garage and made it all work. That was easier than sending it back and dealing with the border issues, etc....
Re: Will a Mopar water pump fit a 440 source housing? [Re: brads70] #1017893
06/21/11 07:31 PM
06/21/11 07:31 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
I have an over the counter OE type water pump on my Source housing and it fit just fine.
Re: Will a Mopar water pump fit a 440 source housing? [Re: Blakcharger440] #1017894
06/21/11 08:36 PM
06/21/11 08:36 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Thanks for the reply! I wonder if the Mopar Performance pump the same only in aluminum? Also wondering if it spaces the pulley out the same?
