"electronic" coil on points ignition? #101769
08/09/08 11:57 AM
08/09/08 11:57 AM
Tampa , Fl
MoparJoe Offline OP
super gas
MoparJoe  Offline OP
super gas
Tampa , Fl
I'm starting to finish up the 318 in my 68 Dart but ran into a minor issue on the ignition side, I had planned on running points in it but all the coils I have laying around are for electronic ignition, is there any issue running one of these coils with points or do I need to get the correct one?
I've always swapped to electronic ignition on everything but wanted to run points in this since no one does it anymore and it's just a stock 318.
Re: "electronic" coil on points ignition? [Re: MoparJoe] #101770
08/09/08 01:01 PM
08/09/08 01:01 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I don't see why not...you'll just need to continue to run the ballast resistor.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: "electronic" coil on points ignition? [Re: goldduster318] #101771
08/09/08 04:24 PM
08/09/08 04:24 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
nice dusters BTW
Re: "electronic" coil on points ignition? [Re: MoparJoe] #101772
08/09/08 04:29 PM
08/09/08 04:29 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If I remember correctly Mopar used the same part when they switched to electronic ignition.
