Re: replacing e body dash harness?
[Re: Annie]
#1016230
06/19/11 01:04 PM
06/19/11 01:04 PM
Posts: 5,783 Corpus Christi, TX
shanker
Corpus Christi, TX
I did a dash restoration (in a 1991 Chevrolet truck) last year and its really best to do this on a bench...that way you can organize the harness like it needs to be, as well as route all the wires easily.
I cant stress how much easier it was with the dash out. Although I ended up swapping the entire dash out anyhow.
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
[Re: 440forPOWER]
#1016232
06/19/11 01:19 PM
06/19/11 01:19 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Removing the instrument cluster without scratching up the wood decal is the hardest part. The wiring is not that hard to remove once the cluster is out. Is it an A/C car? Those are harder
Drop the column, pull the cluster, remove ashtray, radio and glovebox. There's some built in straps that are hard to reattach when re-installing, but it's not that bad either way.
Take lots of close-up pictures as you disassemble, especially of how the wiring is routed around components etc.
It will be a good time to deal with the Amp Gauge Bypass and Wiring Bulkhead Issues when you are in there.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
