wiring a 3 wire denso #1015760
06/18/11 06:48 PM
06/18/11 06:48 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I have a 130 amp 3 wire denso with the internal reg, how do i wire this.
Bear in mind, i have done away with the plugs on the firewall and bypassed the ammeter.
Can i run the hotwire direct to the starter relay.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: wiring a 3 wire denso [Re: deaks] #1015761
06/19/11 03:44 AM
06/19/11 03:44 AM
NY
KillerB Offline
KillerB  Offline
NY
link
Is this the style alt you have?
Re: wiring a 3 wire denso [Re: KillerB] #1015762
06/19/11 11:48 AM
06/19/11 11:48 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
link
That is the way I have mine wired
Gus
64 Plymouth Savoy
Dana 60
Re: wiring a 3 wire denso [Re: fourgearsavoy] #1015763
06/19/11 07:13 PM
06/19/11 07:13 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Yes, it is that style, except it is 130 amp.
I have fitted it today, power and sense wire to the large stud on the relay, ign to blue but can the lamp wire be used as power for a volt meter, also will a 40 amp fuse in the sense wire be big enough.
Thanks Mick
best 60ft 1.36
Re: wiring a 3 wire denso [Re: deaks] #1015764
06/22/11 05:04 PM
06/22/11 05:04 PM
NY
KillerB Offline
KillerB  Offline
NY
Thanks Mick
Pretty sure when I wired mine, the lamp wire was not used , it's just for a dummy light. Just use a 12volt source for volt gauge. The sense wire I believe should be powered when the key is on otherwise the regulator charging circuit would have power all the time. It's been awhile, so don't quote me.
