Yes, it is that style, except it is 130 amp.
I have fitted it today, power and sense wire to the large stud on the relay, ign to blue but can the lamp wire be used as power for a volt meter, also will a 40 amp fuse in the sense wire be big enough.
Thanks Mick
Pretty sure when I wired mine, the lamp wire was not used , it's just for a dummy light. Just use a 12volt source for volt gauge. The sense wire I believe should be powered when the key is on otherwise the regulator charging circuit would have power all the time. It's been awhile, so don't quote me.
