for the 200th time: air cleaner for A12 roadrunner? #1015493
06/18/11 12:31 PM
06/18/11 12:31 PM
delivering your oil
nutso suave Offline OP
delivering your oil
i know this question has been asked a million times, but which air cleaner goes with the A12 roadrunner six pack setup? i am pretty sure it is the 'cold air' version with the lip. then it needs the rubber seal that seals to the bottom of the hood. is this the correct one?
i'm assuming (dangerous i know!) that the non cold air cleaner is for the 70 charger six pack.
any clarification? thanks!
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: nutso suave] #1015494
06/18/11 01:05 PM
06/18/11 01:05 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
NO!!!
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: nutso suave] #1015495
06/18/11 01:08 PM
06/18/11 01:08 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Your image is of a 70-71 fresh air set-up. The 69 A12 base is entirely different. I believe this is also a minor difference in the lid.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: 70gtx440dana] #1015496
06/18/11 01:16 PM
06/18/11 01:16 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Here's a link to start with....I'll be back with more
http://a12mopar.com/yabb/YaBB.pl?num=1239978556;start=all
MikeR
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: A12] #1015497
06/18/11 01:25 PM
06/18/11 01:25 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
well couldn't find what I was looking for but here's a correct base
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: A12] #1015498
06/18/11 01:26 PM
06/18/11 01:26 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
bottom side
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: A12] #1015499
06/18/11 01:27 PM
06/18/11 01:27 PM
delivering your oil
delivering your oil
NO!!!
thanks for the pics! feel free to educate me on the subtle nuances of the six pack air cleaner setup...i have been looking online for a few days and i am finding a lot of conflicting information, and a lot of descriptions without pictures.
i am trying to put together an A12 setup on my roadrunner and i am a bit confused as to which setup is correct.
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: A12] #1015500
06/18/11 01:29 PM
06/18/11 01:29 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Note the correct "wide lip" cover (same as T/A-AAR)
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: A12] #1015501
06/18/11 01:37 PM
06/18/11 01:37 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
there's a thread that I can't locate that shows the differences of the original base with diamond <> shape bridges across the intake of the front and rear carbs for the lid stud and the more rounded shape () of the reproduction (at one time "scam filter base"). Also the filter centering or location tabs spot welded to the base are slightly different too on the reproduction version.
MikeR
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: A12] #1015502
06/18/11 01:41 PM
06/18/11 01:41 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
correct original filter location tab:
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: nutso suave] #1015503
06/18/11 01:41 PM
06/18/11 01:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I hope you have lots o $$$ , they aren't cheap . If you need a lid I have a repop widelip lid I have no use for
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: JohnRR] #1015504
06/18/11 01:43 PM
06/18/11 01:43 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
reproduction filter location tab:
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: A12] #1015505
06/18/11 01:46 PM
06/18/11 01:46 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
correct original:
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: A12] #1015506
06/18/11 01:48 PM
06/18/11 01:48 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
reproduction:
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: A12] #1015507
06/18/11 01:58 PM
06/18/11 01:58 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Nutso, are you looking for the correct OE one, or will a decent repro do?
You may be happy with a cheaper repop rather than track down and pay for a correct one.
I ask because you seem to be building a day three car, which I dig too, but that probably means you aren't going for the paint daubs and diamond vs circle hold down stuff.
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: A12] #1015508
06/18/11 01:58 PM
06/18/11 01:58 PM
delivering your oil
delivering your oil
mine doesn't have to be factory correct...just functional. mine is just a clone anyway.
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: nutso suave] #1015509
06/18/11 05:01 PM
06/18/11 05:01 PM
MO
cdp Offline
cdp  Offline
MO
You can get a repo from Ben Snowbar...i think thats his name.
A bit pricey, but then again, a nice original can set you back 1000-2000k.
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: RodStRace] #1015510
06/18/11 05:01 PM
06/18/11 05:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The repos were $1500 for the BASE when they first came on the scene ..
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: JohnRR] #1015511
06/18/11 05:17 PM
06/18/11 05:17 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
they still are 1500, for just the base. no lid, or element.
lid is another 110, filter is about 100.
now you're in the price range of a real one.
Re: for the 200th time: air cleaner for A12 roadrunner? [Re: Golden-Arm] #1015512
06/18/11 05:39 PM
06/18/11 05:39 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Well, if the repops are that high, what's the point?
