Advice and tips on '69 B-Body FIRM FEEL rear sway bar?
#1014910
06/17/11 10:25 AM
06/17/11 10:25 AM
Posts: 1,037 The New Jersey Hinterlands
Sssnake383
Old and boring
Old and boring
I have a reasonably stock 1969 Road Runner convertible. Does anyone offer a bolt-in style rear sway bar that looks reasonably "factory"?
Any real-world advice on brand/thickness/ease of installation and stock appearance as well as comments on any handling improvements are welcome. Thank you.
Re: Advice on '69 B-Body rear sway bar?
[Re: DAYCLONA]
#1014913
06/17/11 11:14 AM
06/17/11 11:14 AM
Sssnake383
Old and boring
Old and boring
The Firm Feel is about the only bar that's "close" to looking factory, most others are mounted to the axle itself,......a 3/4" bar is about ideal for the rear,....add a 1 1/4 up front along with some 1.00 torsion bars, along with some good shocks if you want to improve your cars handling, along with some poly mounts/bushings
Thank you for the response. The FF website states that the diameter of their rear bar is 3/4". However, I really didn't want to go through the expense and trouble of upgrading the front bar and torsion bars, as well. Right now, the car is stock except for new "Hemi" leaf springs, poly front bar endlinks, and newer Gabriel shocks front and back. It handles decently enough for what it is, but I was looking for a little more stability in the corners.
[Re: Sssnake383]
#1014915
06/18/11 02:34 PM
06/18/11 02:34 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Realize if you add a rear bar without upgrading the front your gonna wind up with a car that oversteers & is generally evil handling... The front suspension needs to be addressed first...
[Re: 1_WILD_RT]
#1014916
06/18/11 02:54 PM
06/18/11 02:54 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I think the 3/4" rear bar would compliment what he has now. Those cars really needed a rear bar for balance. I had the 69 RR large factory bar on the front of my hot rod. It didn't like turning with enthusiasm. Adding the rear bar made a big difference. I like it much better now.
I would add the Firm Feel bar to what he has. The biggest thing he could do to increase the stability of the car would be adding subframe connectors. That chassis is floppy! Tightening the chassis would make a night and day difference.
[Re: feets]
#1014919
06/20/11 11:33 AM
06/20/11 11:33 AM
Sssnake383
Old and boring
Old and boring
Thank you for the encouragement and advice. My Road Runner also has the large diameter bar paired with poly-graphite end links and I'm hoping the addition of the rear bar will really bring the handling up a notch. Most of the body roll certainly seems to come from the rear of the car, not the front.
I'm not really interested in installing subframe connectors. I don't want to cut the floors or weld anything. Bottom line is I'm just trying to get a more pleasant and confidently-handling cruiser from the addition of the rear bar. I'm not trying to go autocrossing (not just yet, anyway).
[Re: ahy]
#1014920
06/20/11 11:36 AM
06/20/11 11:36 AM
Sssnake383
Old and boring
Old and boring
I used the FF rear bar on a '70E. Installation was straightforward per the instructions. I did use some spacers to slightly lengthen the links to position the bar "over the hump". I'm using it with 3" TTI pipes and it all fits well. I use it with FF's larger front bar and 1" Tbars. The car handles great.
Thanks! This is the kind of first-hand knowledge I am seeking. I have the 2.5" TTI tailpipes and was hopeful that the bar would clear the exhaust. After checking out the website pictures and comparing them to the car, I am reasonably sure there won't be any clearance issues.
[Re: Sssnake383]
#1014921
06/20/11 11:01 PM
06/20/11 11:01 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
there are lots of subframe connectors out there that are bolt in - no welding or cutting up the floors at all - ex mancini racing and mopar performance are some of the few that sell them and would definatly help with firming up your ride
[Re: dangina]
#1014922
06/20/11 11:19 PM
06/20/11 11:19 PM
Posts: 7,664 IN
ahy
IN
The 2" square frame connectors from Auto Rust Technicains weld in completly under the floor. Yes there is chassis welding but no impact on the interior. They make a huge difference. You can feel it when driving and see it when you jack up one corner. Much stiffer to help your better suspension pieces do their job.
[Re: Sssnake383]
#1014923
06/24/11 06:27 AM
06/24/11 06:27 AM
Posts: 203 Sante Fe Springs, CA
Hotchkis
Sssnake383 – If you decide to go the extra mile and get some weld-in subframe connectors, we offer a set that bolts in at the rear and only requires a little bit of welding at the front. These are much stronger than any bolt in subframe connector.
http://www.hotchkis.net/subframe_connectors_mopar_bbody_.html
[Re: dogdays]
#1014925
06/28/11 01:28 PM
06/28/11 01:28 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Well, Usually if you add a rear bar the front bar gets bigger to avoid that power oversteer that was mentioned above. If your car has the "large" front bar then a rear bar may clean up handling. You by NO means have to increase torsion bar size for anti-roll bars to work.
So buy and mount the bar and go somewhere safe, pull a sharp corner and get into the gas halfway round the corner. If the rear tires spin and the rear end comes around, you need a bigger front bar. Here's hoping that won't happen. It did happen to me with a '70 Buick GS455 as a 20-year-old and as you can tell it made quite an impression.
R.
Good suggestion that I'd actually recommend BEFORE you buy the rear bar. If you push it hard in a corner and it starts underteering (pushing the front end, feeling like it wont turn) then adding the rear bar will help even it out.
Conversly, if when doing this it oversteers and the rear comes around, adding a rear bar will only make it worse.
IIRC, the standard front sway bar was 7/8. The bigger factory bar was 15/16. These are still small in comparison to the widely available and cheaply obtained aftermarket 1 1/8" bar.
I also will chime in that adding subframe connectors will probably yield greater driving and handling improvements than adding the rear bar.
[Re: TC@HP2]
#1014926
06/28/11 01:49 PM
06/28/11 01:49 PM
feets
Senior Management
Senior Management
Irving, TX
His car has no roof. That chassis will flop around before teh suspension is fully loaded. That's why I suggested the subframes. The little plates the factory used under the car help a wee bit but not much. I bet if he loads that car into a corner it will plow horribly no matter how much throttle is applied. If he slings it into a corner and mashes the throttle it will probably come around on him due to the twisting chassis unloading the inside rear tire and allowing wheelspin.
The rear bar should make a nice improvement regardless of the subframe connectors. I doubt he's going to be road racing it any time soon.
