Re: how do you get your bb mopar elephant ears to seal?
[Re: Jonnyj00]
#1013365
06/14/11 06:26 PM
06/14/11 06:26 PM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
Permatex grey silicone, no gaskets.
One day I will have something cool here.
[Re: Moparnut426]
#1013367
06/14/11 06:50 PM
06/14/11 06:50 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Just use a quality sealer.. The best stuff out there IMO Is called "The Right Stuff" It wont leak no way no how. I have never had any water pump housing sealing problems... Ever and Most all my stuff uses a motor plate too. I made my own elephant ears using 1/4 Mild steel plate, drilled some holes and it works like a charm.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#1013368
06/14/11 07:08 PM
06/14/11 07:08 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
I use right stuff on everthing except them I just use gaskets and never had a leak. One question though is your water pump housing bin mild for the diference in the plate thickness? Cause if it is you may notice the holes get larger the more that is mild off and a gasket will not cover the holes??????
JAKES AUTOMOTIVE
[Re: Jonnyj00]
#1013369
06/14/11 07:11 PM
06/14/11 07:11 PM
Posts: 43,225 Bend,OR USA
Cab_Burge
I use the stock Fel pro blue gaskets, one on each side and sometimes some thermostat housing silicone sealer, sometimes not I ve thought about takine the ears to a machine shop and have them cut both sides of the ears for a O ring around both openings and then use a good hydraulic supply house quality O Ring material to make them with Maybe one of theses days when it won't seal up so easy
[Re: Jonnyj00]
#1013370
06/14/11 07:25 PM
06/14/11 07:25 PM
Thumperdart
State of confusion
Fel-pro blue gaskets and some ultra grey or black and no leaks however, they do need a re-torquing I noticed.
[Re: CHAPPER]
#1013373
06/14/11 07:57 PM
06/14/11 07:57 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I used a pair of SUPERFORMANCE gaskets when I put it in the motor plate on my car.
No sealant or anything else.
[Re: Jonnyj00]
#1013375
06/14/11 08:36 PM
06/14/11 08:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you had a 1 piece plate you wouldnt have nearly the problem that you have with the 2 piece/ears... the 2 plates want to pivot on the bolts
[Re: MR_P_BODY]
#1013376
06/14/11 09:02 PM
06/14/11 09:02 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Well said and you beat me to it Sometimes so with the 1 piece plate if the bolt holes are not close to the bolt size I just use the gaskets and no sealer
[Re: Jonnyj00]
#1013383
06/15/11 10:16 PM
06/15/11 10:16 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
I o-ring mine.............
