how do you get your bb mopar elephant ears to seal? #1013364
06/14/11 06:07 PM
06/14/11 06:07 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
Just wanna know what materials you use and what sealant also! Thank you
Re: how do you get your bb mopar elephant ears to seal? [Re: Jonnyj00] #1013365
06/14/11 06:26 PM
06/14/11 06:26 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Permatex grey silicone, no gaskets.
One day I will have something cool here.
Re: how do you get your bb mopar elephant ears to seal? [Re: sdaurity] #1013366
06/14/11 06:35 PM
06/14/11 06:35 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Any person with a mill can mill you a small rib around the water holes, and then all ya do is fill the rib with a good fast setting sealant, make a tiny crown and it acts like an o ring. Ive seen a few sets like that.
Kasey
Re: how do you get your bb mopar elephant ears to seal? [Re: Moparnut426] #1013367
06/14/11 06:50 PM
06/14/11 06:50 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Just use a quality sealer.. The best stuff out there IMO Is called
"The Right Stuff"
It wont leak no way no how. I have never had any water pump housing sealing problems... Ever and Most all my stuff uses a motor plate too.
I made my own elephant ears using 1/4 Mild steel plate, drilled some holes and it works like a charm.
Re: how do you get your bb mopar elephant ears to seal? [Re: Bob_Coomer] #1013368
06/14/11 07:08 PM
06/14/11 07:08 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
I use right stuff on everthing except them I just use gaskets and never had a leak. One question though is your water pump housing bin mild for the diference in the plate thickness? Cause if it is you may notice the holes get larger the more that is mild off and a gasket will not cover the holes??????
JAKES AUTOMOTIVE
Re: how do you get your bb mopar elephant ears to seal? [Re: Jonnyj00] #1013369
06/14/11 07:11 PM
06/14/11 07:11 PM
Cab_Burge Online work
Cab_Burge  Online Work
I use the stock Fel pro blue gaskets, one on each side and sometimes some thermostat housing silicone sealer, sometimes not I
ve thought about takine the ears to a machine shop and have them cut both sides of the ears for a O ring around both openings and then use a good hydraulic supply house quality O Ring material to make them with Maybe one of theses days when it won't seal up so easy
Re: how do you get your bb mopar elephant ears to seal? [Re: Jonnyj00] #1013370
06/14/11 07:25 PM
06/14/11 07:25 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Fel-pro blue gaskets and some ultra grey or black and no leaks however, they do need a re-torquing I noticed.
Re: how do you get your bb mopar elephant ears to seal? [Re: Cab_Burge] #1013371
06/14/11 07:26 PM
06/14/11 07:26 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Toyota's black silicone. Very tuff stuff. They use it for metal to metal with no gaskets. Like aluminum oil pans ect.
Re: how do you get your bb mopar elephant ears to seal? [Re: Twin Turbo Mower] #1013372
06/14/11 07:46 PM
06/14/11 07:46 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I bet Mazda or Honda would be better....
If you like drag racing, support your local track.
Re: how do you get your bb mopar elephant ears to seal? [Re: CHAPPER] #1013373
06/14/11 07:57 PM
06/14/11 07:57 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I used a pair of SUPERFORMANCE gaskets when I put it in the motor plate on my car.
No sealant or anything else.
Re: how do you get your bb mopar elephant ears to seal? [Re: CHAPPER] #1013374
06/14/11 07:58 PM
06/14/11 07:58 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
RTV black silicone,no gaskets.Let it cure 100% before putting in any coolant.
Re: how do you get your bb mopar elephant ears to seal? [Re: Jonnyj00] #1013375
06/14/11 08:36 PM
06/14/11 08:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you had a 1 piece plate you wouldnt have nearly
the problem that you have with the 2 piece/ears...
the 2 plates want to pivot on the bolts
Re: how do you get your bb mopar elephant ears to seal? [Re: MR_P_BODY] #1013376
06/14/11 09:02 PM
06/14/11 09:02 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Well said and you beat me to it
Sometimes so with the 1 piece plate if the bolt holes are not close to the bolt size
I just use the gaskets and no sealer
Re: how do you get your bb mopar elephant ears to seal? [Re: roadhazard] #1013377
06/14/11 09:22 PM
06/14/11 09:22 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
anarobic sealent
Re: how do you get your bb mopar elephant ears to seal? [Re: Thumperdart] #1013378
06/14/11 09:30 PM
06/14/11 09:30 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Also, I agree that the 2-piece motor plates tend to move around more than one piece and may be more prone to leak.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: how do you get your bb mopar elephant ears to seal? [Re: Dads426] #1013379
06/14/11 10:10 PM
06/14/11 10:10 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
1 piece plate and grey silicone here..no gaskets.
The little old lady from Pasadena is back!
Re: how do you get your bb mopar elephant ears to seal? [Re: Jonnyj00] #1013380
06/14/11 11:06 PM
06/14/11 11:06 PM
NC
440Jim Offline
440Jim  Offline
NC
Permatex silicone sealer and no gaskets. Works great.
Re: how do you get your bb mopar elephant ears to seal? [Re: WILD BILL] #1013381
06/14/11 11:23 PM
06/14/11 11:23 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Same here..not a drop of water at all.First time I've actually had the motor plate sealed since I've been running the car.
Superformance gaskets are the best without any doubt.
Nautilus Racing-
Re: how do you get your bb mopar elephant ears to seal? [Re: Chris2581] #1013382
06/15/11 10:08 AM
06/15/11 10:08 AM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
Thanks guys I have put a couple sets on a couple different cars i just wanted to make sure there wasnt a better way or some trick that would make it easier!! Once again thank you!
Re: how do you get your bb mopar elephant ears to seal? [Re: Jonnyj00] #1013383
06/15/11 10:16 PM
06/15/11 10:16 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I o-ring mine.............
