Wilwood front Brake Drag? #1011630
06/12/11 11:09 AM
06/12/11 11:09 AM
New York
Dustin71 Offline OP
Dustin71  Offline OP
New York
Good morning to all the Mopar Brothers .....
I have a issue with my new Wilwood brake system...
They have a slite Drag to them ....
Can someone give me an idea on what to look for ...
I have a Manual Brake mastercylinder OEM..
Thanks in advance for any help...
Re: Wilwood front Brake Drag? [Re: Dustin71] #1011631
06/12/11 11:17 AM
06/12/11 11:17 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
What brake hoes did u use
Re: Wilwood front Brake Drag? [Re: one bad fish] #1011632
06/12/11 11:26 AM
06/12/11 11:26 AM
New York
Dustin71 Offline OP
Dustin71  Offline OP
New York
Got the Russel Braided Hoses....
Re: Wilwood front Brake Drag? [Re: Dustin71] #1011633
06/12/11 11:29 AM
06/12/11 11:29 AM
Q
Quicktree Offline
Quicktree  Offline
Q
crack the bleed and see if releases, if it does you are holding pressure on the line. make sure the rotor is centered.
Re: Wilwood front Brake Drag? [Re: Quicktree] #1011634
06/12/11 11:31 AM
06/12/11 11:31 AM
New York
Dustin71 Offline OP
Dustin71  Offline OP
New York
You mean the Calipar centered to the rotor/
Re: Wilwood front Brake Drag? [Re: Dustin71] #1011635
06/12/11 11:32 AM
06/12/11 11:32 AM
Q
Quicktree Offline
Quicktree  Offline
Q
yes
Re: Wilwood front Brake Drag? [Re: Quicktree] #1011636
06/12/11 11:33 AM
06/12/11 11:33 AM
Q
Quicktree Offline
Quicktree  Offline
Q
you have to shim the caliper out to get it centered.
Re: Wilwood front Brake Drag? [Re: Quicktree] #1011637
06/12/11 11:33 AM
06/12/11 11:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
centering the caliper is very important
(using the washers)
Re: Wilwood front Brake Drag? [Re: Quicktree] #1011638
06/12/11 11:34 AM
06/12/11 11:34 AM
New York
Dustin71 Offline OP
Dustin71  Offline OP
New York
yes
Yeah... I got that Centered...had to washer shim the calipar but its dead straight
Re: Wilwood front Brake Drag? [Re: Dustin71] #1011639
06/12/11 11:42 AM
06/12/11 11:42 AM
New York
Dustin71 Offline OP
Dustin71  Offline OP
New York
I do see that there is very little travel for the pistons... it almost seems like if the rotor was to thick or to much pad meat...
Re: Wilwood front Brake Drag? [Re: Dustin71] #1011640
06/12/11 11:53 AM
06/12/11 11:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you run this set up yet... I would seat the pads
before anything
Re: Wilwood front Brake Drag? [Re: Dustin71] #1011641
06/12/11 11:53 AM
06/12/11 11:53 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
The wilwood pads are very abrasive new,and making a dragging sound till you get them bedded good.
Hope that's your problem,but if your lucks like mine its not.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Wilwood front Brake Drag? [Re: MR_P_BODY] #1011642
06/12/11 12:00 PM
06/12/11 12:00 PM
New York
Dustin71 Offline OP
Dustin71  Offline OP
New York
before anything
Oh yeah!!! I did drive it for a few days...
They dont lock up but there a little drag to them.... I can turn the wheel with my feet but they don't spin around... they just turn and stop...
Re: Wilwood front Brake Drag? [Re: MRMOPAR622] #1011643
06/12/11 12:02 PM
06/12/11 12:02 PM
New York
Dustin71 Offline OP
Dustin71  Offline OP
New York
Well they don't make noise at all that i could here over the Engine roar, but turning them by hand and no noise...
Re: Wilwood front Brake Drag? [Re: Dustin71] #1011644
06/12/11 12:04 PM
06/12/11 12:04 PM
Q
Quicktree Offline
Quicktree  Offline
Q
crack the bleed open and see what it does. you may have pressure on the line from the brake pedal. where is the ms mounted?
Re: Wilwood front Brake Drag? [Re: Quicktree] #1011645
06/12/11 12:12 PM
06/12/11 12:12 PM
New York
Dustin71 Offline OP
Dustin71  Offline OP
New York
Ok, i'm going to the garage in a few to try that.. i will let you guys know about the cracking the bleeder to see if it releases the calipar.... The MS is in the stock location....
Re: Wilwood front Brake Drag? [Re: Dustin71] #1011646
06/12/11 01:00 PM
06/12/11 01:00 PM
Q
Quicktree Offline
Quicktree  Offline
Q
keep in mind after the brakes have been applied it takes quite a few revolutions for the runout in the rotor to push the pads away from it. I think wilwood says like 10mph
Re: Wilwood front Brake Drag? [Re: Quicktree] #1011647
06/12/11 02:45 PM
06/12/11 02:45 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Oh, don't worry, you'll have plenty of runout with Wiljunk rotors. Mine were .012 NEW.
Re: Wilwood front Brake Drag? [Re: Leigh] #1011648
06/12/11 02:46 PM
06/12/11 02:46 PM
Q
Quicktree Offline
Quicktree  Offline
Q
it's there for a reason I have never had any problems from it
Re: Wilwood front Brake Drag? [Re: Quicktree] #1011649
06/12/11 02:48 PM
06/12/11 02:48 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Shook my front teeth out. I expected them to have tighter tolerances than the $19 O'Reilly rotors.
