Wilwood front Brake Drag?
#1011630
06/12/11 11:09 AM
06/12/11 11:09 AM
Posts: 197 New York
Dustin71
New York
Good morning to all the Mopar Brothers ..... I have a issue with my new Wilwood brake system... They have a slite Drag to them .... Can someone give me an idea on what to look for ... I have a Manual Brake mastercylinder OEM.. Thanks in advance for any help...
Re: Wilwood front Brake Drag?
[Re: one bad fish]
#1011632
06/12/11 11:26 AM
06/12/11 11:26 AM
Posts: 197 New York
Dustin71
New York
Got the Russel Braided Hoses....
[Re: Quicktree]
#1011634
06/12/11 11:31 AM
06/12/11 11:31 AM
Posts: 197 New York
Dustin71
New York
crack the bleed and see if releases, if it does you are holding pressure on the line. make sure the rotor is centered.
You mean the Calipar centered to the rotor/
[Re: Dustin71]
#1011635
06/12/11 11:32 AM
06/12/11 11:32 AM
Quicktree
yes
[Re: Quicktree]
#1011637
06/12/11 11:33 AM
06/12/11 11:33 AM
Posts: 52,972 Romeo MI
MR_P_BODY
centering the caliper is very important (using the washers)
[Re: Quicktree]
#1011638
06/12/11 11:34 AM
06/12/11 11:34 AM
Posts: 197 New York
Dustin71
New York
yes
Yeah... I got that Centered...had to washer shim the calipar but its dead straight
[Re: Dustin71]
#1011640
06/12/11 11:53 AM
06/12/11 11:53 AM
MR_P_BODY
I do see that there is very little travel for the pistons... it almost seems like if the rotor was to thick or to much pad meat...
Have you run this set up yet... I would seat the pads before anything
[Re: Dustin71]
#1011641
06/12/11 11:53 AM
06/12/11 11:53 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
The wilwood pads are very abrasive new,and making a dragging sound till you get them bedded good. Hope that's your problem,but if your lucks like mine its not.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MR_P_BODY]
#1011642
06/12/11 12:00 PM
06/12/11 12:00 PM
Posts: 197 New York
Dustin71
New York
Oh yeah!!! I did drive it for a few days... They dont lock up but there a little drag to them.... I can turn the wheel with my feet but they don't spin around... they just turn and stop...
[Re: MRMOPAR622]
#1011643
06/12/11 12:02 PM
06/12/11 12:02 PM
Posts: 197 New York
Dustin71
New York
Well they don't make noise at all that i could here over the Engine roar, but turning them by hand and no noise...
[Re: Quicktree]
#1011645
06/12/11 12:12 PM
06/12/11 12:12 PM
Posts: 197 New York
Dustin71
New York
crack the bleed open and see what it does. you may have pressure on the line from the brake pedal. where is the ms mounted?
Ok, i'm going to the garage in a few to try that.. i will let you guys know about the cracking the bleeder to see if it releases the calipar.... The MS is in the stock location....
[Re: Quicktree]
#1011647
06/12/11 02:45 PM
06/12/11 02:45 PM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
keep in mind after the brakes have been applied it takes quite a few revolutions for the runout in the rotor to push the pads away from it. I think wilwood says like 10mph
Oh, don't worry, you'll have plenty of runout with Wiljunk rotors. Mine were .012 NEW.
[Re: Leigh]
#1011648
06/12/11 02:46 PM
06/12/11 02:46 PM
Quicktree
it's there for a reason I have never had any problems from it
