freeze plug sealant -if any #1008720
06/07/11 04:34 PM
06/07/11 04:34 PM
Fort Lee, VA
BattleCruiser71 Offline OP
Fort Lee, VA
I'm replacing freeze plugs in a non performance 318, they'll be the usual brass or bronze or whatever they are now.
what if any sealant should I put on them? some sort of locktite? which one?
Ole' Ugly, my 1985 Gran Fury. Luke, my 39,000 mile 77 New Yorker, Darth, my 50,000 mile 60 New Yorker.
Re: freeze plug sealant -if any [Re: BattleCruiser71] #1008721
06/07/11 04:39 PM
06/07/11 04:39 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Permatex Form-A-Gasket.
They make 2 kinds, one that sets up hard and one that doesn't so use the one that fully dries. Clean the heck out of the openings and then wipe a little sealer in the hole and drive the plug home.
Lots of people stick these in dry and never have an issue. My experience is if one does leak it's always the toughest one to get to.
Re: freeze plug sealant -if any [Re: Neil] #1008722
06/07/11 04:45 PM
06/07/11 04:45 PM
Florida STAYcation
dOOc Online penguin-006
The village idiot's idiot
dOOc  Online Penguin-006
Florida STAYcation
What Tater said ... plus maybe even some RTV. They tend to slide-in EZier using some sort of "sealer".
Re: freeze plug sealant -if any [Re: Neil] #1008723
06/07/11 04:45 PM
06/07/11 04:45 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Permatex "brown death", the only thing it's good for.
Re: freeze plug sealant -if any [Re: Neil] #1008724
06/07/11 06:26 PM
06/07/11 06:26 PM
VA
AtomicDog Offline
AtomicDog  Offline
VA
Permatex Form-A-Gasket #1 (fully hardening version) - I just installed a full set of brass deep-cup freeze plugs in the block + heads of a Magnum 5.9 motor and no leaks or issues. While you are at it, if this is a used motor, make sure that you check/clean out the water galleries of crud that builds up in the block with use.
Re: freeze plug sealant -if any [Re: AtomicDog] #1008725
06/07/11 07:27 PM
06/07/11 07:27 PM
Fort Lee, VA
Fort Lee, VA
Thanks guys!
And I love the simple concensus, now It's off to ye olde parts shoppe.
Re: freeze plug sealant -if any [Re: BattleCruiser71] #1008726
06/07/11 07:34 PM
06/07/11 07:34 PM
ill
dennismopar73 Offline
ill
i use 1 or 2 items , weather strip adhesive(gorrilla snot) or i have used indian head,
Re: freeze plug sealant -if any [Re: BattleCruiser71] #1008727
06/07/11 08:17 PM
06/07/11 08:17 PM
VA
AtomicDog Offline
AtomicDog  Offline
VA
Thanks guys!
When purchasing your plugs, don't forget that the freeze plug kits do not include the freeze plugs needed for the cylinder heads (if you are planning to replace them). Those 4 plugs are purchased seperately and are 1-1/4" in diameter, I believe.
Re: freeze plug sealant -if any [Re: AtomicDog] #1008728
06/07/11 09:35 PM
06/07/11 09:35 PM
Another vote for Permatex #1 (gets hard) & b sure & get freeze plugs that are deep (good ole Dormans) or brass
