too much play in power steering unit #1008071
06/06/11 08:33 PM
06/06/11 08:33 PM
Savage MN
sanman68 Offline OP
sanman68  Offline OP
Savage MN
The car is a 1971 Dodge Challenger with factory power steering. I had my power steering gear box rebuilt a few years ago and have not driven the car since. Now I have everything hooked up and you can move the wheel in either direction about 1/8 of a turn before the pitman arm begins to move. From the top you can see the input shaft moving but the pitman arm is not moving. Is there an adjustment for getting rid of the play? Or do I need to get a firm feel gear box? I am in the process of a complete front suspension and brake rebuild.
Sanman
1971 Dodge Challenger Convertible
Re: too much play in power steering unit [Re: sanman68] #1008072
06/06/11 08:39 PM
06/06/11 08:39 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You should have engine running for that test.
Re: too much play in power steering unit [Re: buildanother] #1008073
06/06/11 08:41 PM
06/06/11 08:41 PM
Savage MN
sanman68 Offline OP
sanman68  Offline OP
Savage MN
With the engine running and the system full of fluid the play is the same.
Re: too much play in power steering unit [Re: sanman68] #1008074
06/06/11 09:17 PM
06/06/11 09:17 PM
chicagoland,usa
chicagoland,usa
You could try adjusting it, by loosening locknut and turning screw clockwise a half turn or so and see if that helps. This adjustment is only done with wheels in straight forward position, and you can go too tight so don't lay into it. If the half turn helps, you can try a little more, but when it starts binding, it's time to stop. Sounds like it was rebuilt and hardly used at all?
Re: too much play in power steering unit [Re: buildanother] #1008075
06/07/11 06:11 AM
06/07/11 06:11 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I agree here. My Charger has a rebuilt unit from Firm Feel. It has loosened up a little over the years, so I adjusted it as described above. It made the difference.
Re: too much play in power steering unit [Re: Kern Dog] #1008076
06/07/11 07:49 PM
06/07/11 07:49 PM
Savage MN
sanman68 Offline OP
sanman68  Offline OP
Savage MN
I'll try adjusting it once I get the front end back together. Yes it is a older rebuild but never used. Where is the lock nut?
Sanman
Re: too much play in power steering unit [Re: sanman68] #1008077
06/07/11 08:02 PM
06/07/11 08:02 PM
chicagoland,usa
chicagoland,usa
It's directly above pitman arm, in line with center of pitman shaft, but at very top of box. 3/4" hex IIRC. Possibly 11/16".
Re: too much play in power steering unit [Re: buildanother] #1008078
06/07/11 08:29 PM
06/07/11 08:29 PM
Savage MN
sanman68 Offline OP
sanman68  Offline OP
Savage MN
Thanks so much guys. You are a huge help.
Sanman
Re: too much play in power steering unit [Re: sanman68] #1008079
06/08/11 02:41 PM
06/08/11 02:41 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
If you adjust it too tight, the steering will not return back to straight ahead by itself. BTDT.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
