Turbo ID without tag #1005528
06/02/11 11:04 PM
06/02/11 11:04 PM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Guys,
I have 2 Garrett turbos that have no ID tags. How is the best way to tell what size they are. They have a.96 AR on the exhaust side and a.75 on the cold side. I think they are a T6 flange. They came off a series 60 Detroit. Thanks, Bob
Re: Turbo ID without tag [Re: fbs63] #1005529
06/03/11 11:56 AM
06/03/11 11:56 AM
IL
furious70 Offline
furious70  Offline
IL
take some pics? Get the housings off and measure the inducer and exducer sizes of the wheels.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Turbo ID without tag [Re: furious70] #1005530
06/04/11 01:06 AM
06/04/11 01:06 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
I will post some pics tomorrow. Thanks
Re: Turbo ID without tag [Re: fbs63] #1005531
06/11/11 01:17 PM
06/11/11 01:17 PM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Sorry I took so long guys,been really busy. Anyway here is all the info I got off of them:
Inlet.
A/R .75 M-24 B.O. Garrett
Inlet I.D. 3" O.D. 5"
Exhaust.
A/R .96 M1 GT
Outlet I.D. 3.5" O.D. 5"
Flange bolt pattern is 4.437"x2.75" (T6 I think) I have two pics to post. If you can think of anything I missed let me know.
Thanks, Bob
Re: Turbo ID without tag [Re: fbs63] #1005532
06/11/11 01:17 PM
06/11/11 01:17 PM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Other pic.
Re: Turbo ID without tag [Re: fbs63] #1005533
06/13/11 11:31 AM
06/13/11 11:31 AM
IL
furious70 Offline
furious70  Offline
IL
Does the turbine inlet have any numbers stamped on the inside? .96, 1.23, 1.32, 1.6 would be common.
You'll really need to take the housings off to measure the wheels to know for sure what you have.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Turbo ID without tag [Re: furious70] #1005534
06/13/11 06:33 PM
06/13/11 06:33 PM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
I will do that tonight. Thanks
Re: Turbo ID without tag [Re: fbs63] #1005535
06/14/11 12:53 AM
06/14/11 12:53 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Here is what I found. Inlet side impeller is 4.030"(102mm). The exhaust side is 3.700" (94mm).The intake side has A/R .75 cast into it. The exhaust side has A/R .96 cast into it and also is stamped .96 right inside the flange.
Re: Turbo ID without tag [Re: fbs63] #1005536
06/14/11 01:55 PM
06/14/11 01:55 PM
Irving, TX
feets Online tonguue
Senior Management
feets  Online Tonguue
Senior Management
Irving, TX
Try that again.
- Stu Harmon
Re: Turbo ID without tag [Re: feets] #1005537
06/14/11 08:47 PM
06/14/11 08:47 PM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
OK. On the intake side the inducer is 4.030" and the exducer is 3.030". The exhaust side inducer is 3.700" and the exducer is 3.438"
Thanks, Bob
Re: Turbo ID without tag [Re: fbs63] #1005538
06/14/11 09:57 PM
06/14/11 09:57 PM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
Bad turbo you should sell it to me. LOL What are you trying to do? Very large for twins but as a single motor like mine it will work well. That is pretty much the exhaust side I need for my motor. If you want to part with one let me know.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: Turbo ID without tag [Re: CW25] #1005539
06/15/11 03:43 PM
06/15/11 03:43 PM
IL
furious70 Offline
furious70  Offline
IL
Not bad at all, a 76mm turbo with an 87mm turbine and .96 housing. You're already on a 1.32 housing, right Curtis? What wheel do you have?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Turbo ID without tag [Re: furious70] #1005540
06/15/11 11:42 PM
06/15/11 11:42 PM
CW25 Offline
CW25  Offline
1.0 hsg and 83mm/75mm turbine.
